Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Tutorial: Booting XP from a USB device...
    FLAC mbkowns's Avatar
    Mar 2004
    What ever happened with this ? Were boot times ever good? Did hibernate get fixed?
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    MBK (AIM = IllMBKllI)
    FLAC SFiorito's Avatar
    May 2004
    Hey guys, someone emailed me a link to this message board where a fellow by the name of Dietmar managed to hack XP into booting from any USB device by mod'ing the USB driver registry entries. I haven't had the time to test this myself, but if it indeed works it's a huge leap (IMO) for XP hacking. Others in the XPe community had tried hacking the boot order and CriticalDevicesDatabase registry entries before, but were never successful. This guy did it. There are still a few questions I have on how well it'll work with, for instance, ACPI (same problem there currently exists in XP and XPe when booting from a removable CF disk where ACPI freezes the PC).
    I'm going to be out of town for a few days so I won't be able to try it out until late next week. BTW, this is different than what BartPE does, which is USB RAM booting. This actually boots and runs the OS from the USB disk. Note that you could also use it with a USB external HDD which then removes the need for EWF.
    Take a look here:
    FLAC IntellaWorks's Avatar
    Jun 2004
    This is definatly interesting. Great find!
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Apr 2005
    San Francisco, CA, USA
    This is the best news ever. Now we can use a small flash drive for OS and apps. That will fit easily into any case or be quickly removed to add apps. I have been looking for this solution for over a year now. Thanks for sharing!
    Variable Bitrate wallaceacura's Avatar
    May 2005
    SE Wisconsin
    Has anyone tried this yet?
    With WI temps dipping into the teens now, it would be nice to be able to boot from the USB HD and bring it in at night. I don't have a reboot switch yet, so I have to pull over and turn the car off to get it to reboot. Not very elegant.
    Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
    May 2004
    I'm planning to probably in the next few days. Just too much stuff going on right now between work and school.
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    How about booting from an iPod nano/shuffle???
    08 Lincoln Navigator
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    Quote Originally Posted by MobiTekLink
    Great idea.....
    or any portable USB drive.....
    I have seen linux boot on a USB key..... (Damn small linux).... the board has to support USB HDD boot (most Epia do this). HP has a program called "HP USB Disk storage format tool" that will allow you to format any USB device and write system files....
    If you have the winxp boot image you should be able to write that to the USB key(the same process as making a bootable CD)......
    I hope this helps some.....
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Installed & Working....
    Custom enclosures
    Newbie Guide
    Jun 2006
    Has anybody done this with their CarPc?
    I was wondering if anyone has booted XP from a usb device such as a flashstick or a usb Harddrive?
    If so, I would like to purchase a usb harddrive and be able to make it bootable so I could use it with my laptop. If possible, I would like to be able to use my laptop as normal when it is out of the docking station, which is in my car, and when it is loaded into the docking station, it boots from the USB hardrive, which then loads tinyXp or one of the other mini XP shells.
    Would that work?
    May 2004
    I've booted XP both from USB with both flash and a HDD. Works well and is fast. It can be a pain if you're not comfortable with registry hacking though.
    As far as what you want to do, it seems reasonable as long as your laptop BIOS supports USB booting AND supports USB 2.0. If it has a recent PhoenixBIOS or AMIBIOS then you should be fine.
  1. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 05:09 PM
  2. Replies: 14
    Last Post: 08-15-2005, 06:27 PM
  3. booting up from a usb disk-on-key
    By knight17 in forum General MP3Car Discussion
    Last Post: 04-16-2005, 09:23 PM
  4. Replies: 4
    Last Post: 09-12-2003, 05:15 PM
  5. Haicom USB and XP!
    By Daz in forum GPS
    Last Post: 08-29-2003, 10:33 AM
