Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Help Neede @ My Life End With Cf & Xp
    Oct 2005
    Yeah i am a n00b and i have searched but i need help.
    I am 4 CF cards and a few CF-IDE connectors down and alot of money down the drain lighter.
    I cant install XP and get it running on CF.
    SP13000.
    Kingston high speed 4BG CF.
    Tranquil pc IDE-CF Adapter.
    1:-I have tried to install stright to CF but i cant get the paging file active so i cant update windows or install net-framework,autoroute etc etc
    2:-I have installed onto a normal harddrive and then tried to ghost it over, cant get it to work. closest i get it is stuck on the window screen.
    HOW THE HELL DO I DO IT !!!! after 15 installs of window 98, ME, XP , XP PRO, XP HOME, XP TALBLET, XP CORP etc etc ...
    Please help noob newbie to achive his goal. MAYBE AN IDIOTS GUIDE.
    Thanks in advance from the UK
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Bloody hell, weve had double posting before and even three, but four in the same forum??????
    Edit make that 5
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    Posting the same thing 5 times is not a good way to attract attention around here!
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Oct 2005
    Sorry my PC froze and as usual i hit send a number of times...
    SORRY GUYS Please help...was not done on purpose
    As long as it wasn't intentional!
    I dont know too much about installing windows on a cf card but here goes:
    It seems windows has a problem with the page file being on the cf card, this may be because the cf card has a limited number of read/write cycles. But then windows should just treat it as any normal drive and just use it untill it eventually dies from to many reads/writes.
    It's a mystery to me!
    Fox Mulder
    2004 Toyota MR2
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Fox_Mulder
    <insert comment about the truth being out there>
    <insert comment about it being a conspiarcy>
    Quote Originally Posted by Enforcer
    a conspiarcy
    I was waiting till I had some proof of aliens (and of course the government) preventing him from loading XP on the CF Card
    Fox Mulder
    2004 Toyota MR2
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    You can install windows onto the drive, but you must get a utility from the card maker to switch it to fixed disk mode so that windows will not freak out on it. The other thing your going to need to do is install EWF (Enhanced Write Filter) or your cards are going to be dead within a few days.
    If you can find it your much better of going with Windows XP embedded, i've got it running on a 1gb flash card with no problems at all.
    肚子笑痛了
    S60 Install
    FLAC SFiorito's Avatar
    May 2004
    Oct 2005
    Is the embedded way a big hasstle.
    I just want the pc running with miniml apps.
    can somebody point me to the link which is entiled " how to install windows xp to cf in easy steps"
    Worth a try
    cheers
  1. FAQ: Boot directly into your front end
    By d_sellers1 in forum The FAQ Emporium
    Last Post: 03-06-2010, 05:22 AM
  2. Replies: 85
    Last Post: 07-09-2007, 05:44 AM
  3. Damn visual basic
    By BiohazrD in forum Software & Software Development
    Last Post: 02-04-2005, 02:10 PM
  4. Telematics.net
    By IntellaWorks in forum Software & Software Development
    Last Post: 11-05-2004, 09:20 PM
  5. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
