Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 640x480 at startup
  1. #11
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Reset your BIOS jumper, then reboot, get into BIOS, make sure video is set to CRT+LCD, and your resolution is set to 800x480. I assume you have the latest BIOS that has support for 800x480?
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
  2. #12
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    The latest BIOS only has windows suppport for 800x480, not DOS/POST
    I've spent weeks 'ing for this problem and only found other asking the same question... No solutions!
    Its a Windows problem I'm convinced.
  3. #13
    Sep 2003
    Tampa, Florida
    I had a problem with my laptop that's kinda related. The laptop has a 1280x800 widescreen. I just installed Battlefield 2, and wanted the latest ATI drivers. I cleaned out the old drivers, then installed the new ones. After that, windows wouldn't show an option for 1280x800. The max was 1024x768. I was kinda bummed. After searching alot on the 'net, I found you could download Powerstrip and "force" it to 1280x800. after forcing it, and restarting a few times, it worked beautifully. While I was cleaning out my HDD, I removed Powerstrip. When I re-booted, 1280x800 was still available, even though Powerstrip was gone. I think it modified the registry or something, and didn't undo the resolution options when it uninstalled. Maybe you can try the same thing, and windows will "stick" so using the resolution you want after using Powerstrip.
    WORKLOG
    Webpage
  4. #14
    Aug 2004
    On the edge!
    When I finally get a CDROM drive connected I will try that one, cheers.
    A few other things to try also...
  1. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 11:55 AM
  2. Replies: 14
    Last Post: 12-09-2005, 03:03 PM
  3. XM as startup command
    By skippy76 in forum RR Bug Tracker
    Last Post: 10-07-2005, 06:01 PM
  4. Startup is too fast!!!
    By EBFoxbat in forum General MP3Car Discussion
    Last Post: 02-05-2005, 10:20 PM
  5. Any 640X480 F.P. Skins?
    By Boostz21 in forum FrodoPlayer
    Last Post: 12-30-2004, 05:25 PM
