Results 1 to 2 of 2
Thread: Xenarc 700IDT TouchKit component for XPe?
    Jan 2004
    St. Louis
    Anyone on here successfully compiled Xenarc's TouchKit (USB Universal) component for XPe? I had this low on the priority list because Xenarc had the embedded drivers on their website already but after I compiled them, the fricken coordinates are all off. I know you can mess with the .inf file to re-arrange these coordinates but the values don't make any sense.
    Jan 2004
    St. Louis
    I wrote Xenarc and they're working with me on my project....
    Xenarc Support <[email protected]> wrote:
    We do not have any experience with these drivers in XP Embedded. We will
    have to contact the touch driver manufacturer to see if they can help. We
    will forward the information to you shortly.
    -----Original Message-----
    Sent: Friday, January 20, 2006 3:16 PM
    To: [email protected]
    Subject: Re: EdgeInfo
    Unfortunately, the config utility for XPe is not part of your instructions.
    I can build the driver add it to the Target Designer and it works on the
    build. It's just not calibrated. Can you provide me more variable info for
    the inf file so I can edit it with the necessary variables to read the
    Date: Fri, 20 Jan 2006 14:56:52
    Subject: RE: EdgeInfo
    Have you tried calibrating the touch screen after installing the drivers?
    Start the Touchkit Configure Utility (Start -> All Programs -> Touchkit ->
    Configure Utility). Highlight the USB device in the Active Panel window,
    then click Calibration (or 4-pt. Cal.). Press and hold the blinking X until
    you hear the computer beep. Release the X and it should reappear in the
    next corner. Repeat on 4 corners.
    The Edge compensation allows you to make adjustments in the calibration that
    will make it easier for you to move the cursor closer to the edges of the
    monitor. More info can be found in the documentation found on the driver
    install disk.
    Sent: Monday, January 16, 2006 3:29 PM
    Subject: EdgeInfo
    Dear Sir/Madam,
    I've been diligantly trying to build a driver component for your 700IDT
    Touch Screen Driver. I downloaded the drivers and followed the instructions
    but the touch and mouse seem to always be off and opposite of what it should
    be. Can you provide more information as to what the EdgeInfo parameters
    suggest. Are these supposed to represent pixels, etc.? If you can
    re-direct me to stronger information, I'd greatly appreciate it!
    BlackBerry service provided by Nextel
    I'm a little worried though on the actual knowledge of customer service and their ability to know what I'm needing to finish the component. (Granted, I wasn't very specific in my inquiry...oops) Anyway, they provide XPe drivers and instructions to building a component for their monitors on their website, yet from his/her email, they say they don't support XPe. If Xenarc's contact for the touchscreen is able to help me with the .inf variables and I build a successfull component, I'll post the "How To..." here or just let you download it. It's up to you guys if you want to learn XPe or do you want to plug and pray.
  1. Dont buy a Xenarc 700IDT!!!
    By cdcamaro9534 in forum LCD/Display
    Last Post: 04-12-2006, 05:29 PM
  2. Installing CD/DVD in Xenarc 700IDT
    By primusx1 in forum LCD/Display
    Last Post: 12-18-2005, 02:04 PM
  3. Voice nav on xenarc 700idt?
    By hotponyshoes in forum General Hardware Discussion
    Last Post: 11-08-2005, 03:03 AM
  4. Xenarc 700IDT is AMAZING!
    By spdyscotty in forum LCD/Display
    Last Post: 11-02-2005, 09:52 AM
  5. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
