Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Trouble with Embedded
  1. #11
    Jan 2006
    no i do have it installed, or else i wouldnt be able to ping myself. i cant run ipconfig because of an error "win64fsredirection is missing in ntdll.dll" or something like that.
  2. #12
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    can you post the exact error message you are getting when you try to run IPCONFIG ?
    if you do have TCP/IP completely installed.. it seems like it is corrupted somehow..
  3. #13
    Newbie Extent's Avatar
    Jun 2004
    It probably bears mentioning that the the loopback device is actually a seperate device from your NIC, and even if you don't have working drivers for your NIC you'll still be able to "ping yourself" using localhost.
  4. #14
    Jan 2006
    but i checked the registry and it said that tcp/ip successfully binded to my network card or driver. not sure if that suggests the presence of a correct driver tho...and i used the driver that appeared from device manager.
  5. #15
    Jan 2006
    we can safely eliminate the possibility of driver problems!!! just added device manager and my network card was detected. anything else that i might be missing? whats that hidden WAN miniport device in device manager for?
  6. #16
    Aug 2004
    Pearland
    Quote Originally Posted by betatester35
    how do you check the registry for that??
  7. #17
    Jan 2006
    well umm its kinda complicated, but the point is i need a solution to my problems...<_<
  8. #18
    Jan 2006
    and some more questions. is it possible to manually set the dhcp server? i have 255.255.255.255 when i want it to be 192.168.1.1.
  1. Little trouble using NaviPC embedded
    By paperinics in forum RR Bug Tracker
    Last Post: 03-29-2005, 08:14 AM
  2. Screen size of IGuidance Embedded in FP
    By PDiddy in forum FrodoPlayer
    Last Post: 02-11-2005, 07:07 PM
  3. Extracting Embedded Web Video
    By VanMan69 in forum General MP3Car Discussion
    Last Post: 02-10-2005, 03:27 AM
  4. Newbie embedded MP3++ system
    By Steinola in forum Newbie
    Last Post: 05-16-2004, 09:49 AM
  5. Running WinTV embedded in MediaCar
    By badandy4you in forum MediaCar
    Last Post: 05-12-2004, 01:57 AM
