Results 1 to 4 of 4
Thread: CF boot. CF Shows up as D:
    Jan 2006
    After following Sfiorito's EWF guide down to every tiny detail, there is one problem that i just cant sort out. My CF boots fine into DOS, and apparently transferring the files from HD to CF is done correctly. However, when I do my initial boot from CF, it almost resumes from hibernaion in complete, but always leads to a BSOD. Pressing F8 while booting gives me the option to "delete retoration data" and do a "fresh" boot. Doing this makes my CF appear as drive D, and obviously the drive is no longer "protected" by EWF..
    Any ideas?
    Best regards, Ketil.
    FLAC SFiorito's Avatar
    May 2004
    do you still have the HDD plugged in when you boot up?
    Jan 2006
    No other drives connected, only the CF which is set as master.
    Ps: Thanks for sharing your knowledge and spending time with us here SFiorito. Its highly appriciated!
    All the best, Ketil.
    Oct 2005
    Linz, Austria
    I had the same problem this week.
    Here is a fix:
    http://www.petri.co.il/change_system...windows_xp.htm
    It worked for me.
  1. Replies: 10
    Last Post: 04-17-2006, 05:23 PM
  2. I cant get my computer to boot my CF Card
    By csnowman00 in forum General Hardware Discussion
    Last Post: 03-15-2005, 12:10 AM
  3. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 06:48 PM
  4. CF universal Boot Hardrives !!!
    By chuckctv in forum General Hardware Discussion
    Last Post: 09-04-2004, 10:27 PM
  5. boot from CF?
    By etrik in forum General Hardware Discussion
    Last Post: 02-09-2002, 01:08 PM
