Results 11 to 20 of 23
Thread: minlogon integrated directly to nLite image
  1. #11
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    OK I found an elegant solution. Winlogon can not be replaced that way outlined above, the reason is instalation freezes after first boot, probably beacuse of the way instalator handles user accounts. Anyway, the solution to this is to create a .CAB file containing silent installer that replaces winlogon with minlogon and imports its registry keys and integrate this .CAB add-on as an hotfix within nLite. This way, no manual steps are needed.
    Simple, elegant.
    I have tested first version of installer. Its not fully silent as there is Regedit popup on first boot asking for your confirmation to import minlogon registry key - this will be fixed in next release along with script to delete OEMBIOS.* files (no longer needed with minlogon - bye bye and unused user accounts).
    For anyone interested, I can post add-on here upon request.
  2. #12
    Mar 2005
    Czech republic
    Update: second version of minlogon add-on is available.
    Changes:
    a) completelly silent
    b) removes OEMBIOS.* files within SYSTEM32 folder (no longer needed with minlogon)
  3. #13
    Oct 2005
    Fayetteville, AR
    I'll bite... setting up my first nlite config now, i could use the addon. Thanks!
  4. #14
    Jul 2004
    I'd like to give this a try too. I have a partition on my carputer that I use for testing out different nlite installs. Still havent gotten the perfect install yet so this will be quite useful for me.
    Carputer installed!!!
    Nlited XP+Minlogon, EpiaM10k, 512mb, Seagate 40 gig 2.5" HD, FM Dlink usb radio, DWL122 USB Wifi, XMD1000 tuner, PT5071 6 amp regulator, Xenarc 700TSV, and 1 ikea key box.
  5. #15
    Mar 2005
    Czech republic
    All right, here you go:
    Minlogon nLite add-on, rev. 02
    Instructions: integrate in nLite as normal hotfix. Note that I only tested this add-n with WFP disabled. I do not think this add-on will ever work if you keep WFP enabled.
    Once the nLited WinXP is installed, you will be running with minlogon automatically. No more registry hacking, no messing with winlogon executable, no reboots.
    If you are perfectictonist like me, you might want to delete winlogon.--- file from SYSTEM32 folder as this is leftover that can not be deleted from within add-on itself. You also might want to delete any remaining user account, including Administrator one, as only Default user is used with minlogon.
  6. #16
    Jul 2004
    Thanks!. I'll give it a try this weekend.
    -momanz
  7. #17
    Jun 2006
    does this work windows xp SP0 ?
  8. #18
    Mar 2005
    Czech republic
    in respond to your PM: extract it from CAB refferenced in post #15, duuuude.
  9. #19
    Jun 2006
    is there a minlsass.exe maybe ?
  10. #20
    Mar 2005
    Czech republic
    what for?
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 06:41 AM
  2. Touchscreen problems with nlite and minlogon
    By Ascension in forum WinNT Based
    Last Post: 06-01-2005, 06:18 AM
  3. nlite image file
    By Cheekz185 in forum Software & Software Development
    Last Post: 05-04-2005, 09:30 AM
  4. nLite image - Bootvis won't optimize
    By kpjuk in forum WinNT Based
    Last Post: 02-01-2005, 08:45 PM
  5. Replies: 2
    Last Post: 01-05-2005, 08:22 AM
