I don`t really see how this be done with nlite.
You could apply the minlogon.exe over the winlogon.exe within the cab files in i386 folder however..
when you do your install windows, it will crash out and reboot because you need to apply the registry hack:
Code:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"Config"=dword:00000017
It is alot quicker and easier to do it following sfiorito instructions
http://mason.gmu.edu/~sfiorito/eXPinstall.htm
Alternatively this post may be better in the nliteos forums they have more experience
If you are having problems with over writing the 470kb winlogon.exe with the 17kb minlogon.exe someone has created a quick app on the forums some where I saw it a couple days ago whilsts
Alternively try my method:
goto:
windows/system32/dllcache
right click select properties of winlogon.exe untick the readonly box.
do the same with
windows/system32/winlogon.exe
rename minlogon.exe to winlogon.exe copy it and paste it over
Quickly select
windows/system32/
and paste the copy into here aswell.
if you do it before the 5-10 second refresh of dllcache then your new copy will be inplace
if you need to check you have the correct versions in place do a reboot go back into both directories and the file size should be 17kb not 490kb of winlogon.exe if they are 490kb then you were too slow and the refresh occured
Please make sure you have taken a back up of the original 490kb winlogon.exe
AND BEFORE THE REBOOT MAKE SURE YOU APPLY THE REGISTRY HACK or your computer will constantly reboot with the new winlogon 17kb in place; i have done this. :P
now give it a go..
I have done this on 4 different machines with no probs
