Results 1 to 10 of 14
Thread: **Bootup Problems!!**
    Feb 2006
    I'm hoping you guys can help me out on this one.
    I have a M10000 Mobo, 512 ram, 120WD harddrive, running on XP. Power supply is M2-ATX. The supply is wired to my 1farad capacitor which is obviously then connected to the battery. Computer starts fine this way. BUT:
    Starting yesterday, when I turn the ignition on, the computer turns on but Windows will not bootup. It just goes to the system configuration screen basically listing out what all is on the system. Looks to be all the hardware. I have to manually unplug the PSU from the mobo to turn it off because since it didn't bootup, it won't shutdown and therefore stays powered up even witht the key out.
    I have tried rebooting like 4 or 5 times, but it still does the same thing. Funny thing is, though, that every 5th or 6th bootup will work fine. Sometimes it will say, " sorry for the inconvinience but windows did not start properly, what would you like to do?" And then i select "Start windows normally."
    I definitely don't want to go through this everytime I start my car, so what should I do?
    Any ideas? Thanks
    Variable Bitrate DaveB's Avatar
    Mar 2004
    Do you have an external DVD drive connected via a USB cable? If so, that is your problem. If you disconnect the USB cable it will consistenly boot properly.
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    Feb 2006
    Yes I do, so how do I correct this? Or am I gonna have to connect the drive only when I use it and after bootup?
    Oh and thanks for the help...im glad it's such an easy fix
    Mar 2004
    Customtl,
    You can verify the problem. Boot the PC. When it stops after counting memory and just sits there....unplug the USB cable from the DVD drive. If the boot process breaks loose and starts to continue to run as normal, you'll know you had the same problem that I had.
    My external DVD enclosure had both a USB port and a firewire port. I was never able to solve the USB problem. Nothing in the BIOS had any effect. Changing USB drivers did nothing. I eventually bought a firewire cable and used it instead instead of the USB cable and that solved my problem.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Feb 2006
    Oh nice...sounds good...although I don't have a firewire port, but I have plugged the drive in after bootup and it still worked (the drive, cuz some things via usb or ps2 slots have to be plugged in before bootup). So thats no biggie...most everything is on my harddrive anyways and the usb is plugged into a remote hub that is easily accessible.
    Again, I really appreciate your help.
    -Ryan
    Mar 2004
    Ryan,
    Glad to help. I found my drive didn't always work after I plugged it in when the PC had finished booting. I had really bad experiences all the way around with USB and a DVD drive.
    I think the problem is these mini-ATX motherboards aren't quite as stable in some areas as the full-size motherboards.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
    Mar 2006
    this may sound weird, put try plugging it into a different usb port. On my comp, if you have the iPod cable plugged into a certain port, windows wont boot, but if you plug it onto the other port, it does... Go figure.
    Variable Bitrate Philhop's Avatar
    Apr 2006
    any soloution? i have this problem too!
    Aug 2006
    Central PA
    Ever figure this out?
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by scotty562 View Post
    disable usb boot from bios it might help
