I see it on my TinyXP build, under control panelOriginally Posted by mick0uziel
Im gettin about 24seconds using a M10000, 1Gig w\of ram....plug and play does work..i used my usb drive, WinTV USB, and IR receiverOriginally Posted by mick0uziel
thanks, the keyboard was fixed. i am using a 1ghz nehemiah with 1gb of ram. getting it at about 40 seconds from pressing the power button upto loaded RR. how did you tweak it to be faster?
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
ive got another problem, i reformatted my computer again and installed tinyxp, now when i try to install mapmonkey.exe, it says"an error occured while reading file, it doesnt want to install, i downloaded mapmonkey again from the website, and vb runtime, but still have errors. any tips. thanks
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
i cant download![]()
any other links for me?
not sure maybe ask the author of MapMonkey what else is required
FYI,
Updated 1st post....
links still dont work. I really want to try this out.Originally Posted by camsgs3
I burned the iso, and how in the world do i install this ??
the same way you would install any FULL version of Windows....boot up your PC with the disk in the drive, make sure ur bios is set to boot from the CDROM fist then harddrive 2nd..Originally Posted by hoodlum
then it should say presss any key to boot from the CD.....
