Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 119
Thread: TinyXP Rev04 + FrontEnds
  1. #41
    Mar 2004
    i did the install then it restarted to go into windows install part 2. then it get Setup starting then Fatal Error.
    An error has been encountered that prevents Setup from continuing.
    One of the componentsd that windows needs to continue setup could not be installed.
    The parameter is incorrect.
    Press OK to view the Setup log files.
    [OK]
    in error log it shows D:\I386\asms. error message the parameter is incorrect.
    What should i do.
  2. #42
    Mar 2005
    I have a problem with my bluetooth usb dongle. regular plug-n-play doesnt seem to work for me even though the service is turned on. on my regular desktop i just connect the dongle and i get the standard "new device found" window and XP sets it up for me fine and i can see bluetooth devices in my control panel. when i try it on my tinyxp box it doesnt even detect it. i dont see it in my control panel either. any ideas?
  3. #43
    Jan 2004
    NYC
    Quote Originally Posted by hoodlum
    [OK]
    What should i do.
    where did you get the ISO from? could be a corrupt one, maybe burn another disk, if that dont work then maybe ur ISO is damaged
  4. #44
    Jan 2004
    NYC
    Quote Originally Posted by inferno2469
    i didnt try my BT dongle yet. But my USB Hub and USB stick are workin fine with this build...
    so im not sure....
    Are you using the minlogon setup? cause i beleive that disables the plug and play
  5. #45
    Mar 2005
    Quote Originally Posted by camsgs3
    so im not sure....
    yes using mini logon setup. my usb hub is working ok as with my usb keyboards and mouse. im gonna try a reinstall of tinyxp
  6. #46
    Aug 1999
    Washington D.C.
    Are you guys getting into trouble with copyrights here?
  7. #47
    Jan 2004
    NYC
    Quote Originally Posted by Zip-Lock
    i dont think soo...if soo let me know what to remove
  8. #48
    Jul 2004
    Hi Guys,
    Just wondering what's the attraction here? You can chop an XP iso image down to 150 meg with Nlite and you know exactly what you've removed in doing so. If you combine Nlite with the guide at this site you can get an xp install down to 300-350 meg or less depending on what functionality you want to keep. Don't mean to start a flame war here. It just seems if you're going to spend as much time as you are on your OS image you may be better off going a different route?
    Cheers,
    momanz
    Carputer installed!!!
    Nlited XP+Minlogon, EpiaM10k, 512mb, Seagate 40 gig 2.5" HD, FM Dlink usb radio, DWL122 USB Wifi, XMD1000 tuner, PT5071 6 amp regulator, Xenarc 700TSV, and 1 ikea key box.
  9. #49
    Jan 2004
    NYC
    Quote Originally Posted by momanz
    Hi Guys,
    Cheers,
    momanz
    I hear ya, this tinyXP build requires nlite..but the thing is that when people start building there own image using nlite...they might remove something that is required to work with XP, or they dont know what to remove/add
    When i first started to mess around with nlite, i built about 8 different ISOs because it was always missing something or something was not workin right and that took alot of dam time...
    with this tinyXP version it works rightaway all you doo is enter your LEGAL XP key[change the winn.sif file in the i386 dir] and ur good to go.
    Basically this is a time savor and it works great so far
  10. #50
    Mar 2004
    Anyone have any trouble getting BT to work with tinyxp? I can't seem to get it to function properily! And now I lost my sound lol, sound card installed, everything good, but just no sound.
  1. hibernating in tinyxp
    By @rie in forum Operating System Optimization
    Last Post: 02-04-2010, 10:58 PM
  2. TinyXP Rev04 + FrontEnds THREAD GONE..
    By camsgs3 in forum Operating System Optimization
    Last Post: 11-13-2006, 07:14 PM
  3. TinyXP bluetooth issue
    By inferno2469 in forum Operating System Optimization
    Last Post: 09-13-2006, 12:14 AM
  4. TinyXP Installation
    By swiftly93 in forum Centrafuse
    Last Post: 05-25-2006, 09:34 PM
  5. tinyxp rev04
    By hoodlum in forum WinNT Based
    Last Post: 05-16-2006, 01:15 PM
