Page 9 of 12 FirstFirst 123456789101112 LastLast
Results 81 to 90 of 119
Thread: TinyXP Rev04 + FrontEnds
  1. #81
    Aug 2005
    Plano/College Station, TX
    Quote Originally Posted by pcfreak
    If your computer allows booting from usb in the bios then that would not be your problem. But if you don't see that option then I would have to say yes that is your problem. It's not a cdrom until it gets into windows.
    I figured that was the problem and went ahead and hooked up a regular CD rom drive. Worked like a charm!
  2. #82
    May 2006
    just did this to my friends computer... but now the @ key and " key are swapped..... the 2 key and ' key still are the same... any idea how to fix this
  3. #83
    Nov 2005
    CT
    Quote Originally Posted by allahsone
    TinyXP hads the keyboard set to the UK standard. You need to change it to US under the control panel, region and language.
  4. #84
    Newbie Howie's Avatar
    Jun 2006
    Adelaide, Australia
    FYI,
    For those of you wanting to install Via4in1 drivers on TinyXP Rev 04
    If you're having problems getting the via 4in1 chipset drivers installed.. you should use the Hyperion version instead. Seems to be a problem with the installer on the 4in1 that prevents it from starting the install software.
    Via Hyperion 4in1 cam be downloaded from here :
    http://www.viaarena.com/default.aspx...D=1&CatID=1070
    Progress: 50% [▓▓▓▓▓▓▓▓▓▓----------]
    Athlon 1200 M-Atx
    usb-wifi, usb-gps, usb-tuner, usb-bluetooth
  5. #85
    Aug 2005
    I thought it was a 16bit issue. I made my own image and added 16bit back in and they work fine.
  6. #86
    Jun 2006
    Adelaide, Australia
    Or i guess you could do that.
    Athlon 1200 M-Atx
  7. #87
    May 2006
    as most of you know windows is creacking down people with bootleg copies of XP.... but if i nstall tiny on my pc... would i still be able to update liek windows media player and what not... also sp2..... thanks
  8. #88
    Jan 2004
    NYC
    Quote Originally Posted by allahsone View Post
    You can use your own legal XP Pro key with tinyXP, open the .iso in winiso, go to the i386 folder, look for a file called winnt.sif, open it with notepad....replace ur key with the one already in there, click save(iso) and burn...and i believe SP2 in intergrated already in Rev4
    [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
    [iGmon]
    Download MP3 MixTapes
  9. #89
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    This is old a Rev 5 is already out
  10. #90
    May 2006
    What do i need to add to get fast user switching..
  1. hibernating in tinyxp
    By @rie in forum Operating System Optimization
    Last Post: 02-04-2010, 10:58 PM
  2. TinyXP Rev04 + FrontEnds THREAD GONE..
    By camsgs3 in forum Operating System Optimization
    Last Post: 11-13-2006, 07:14 PM
  3. TinyXP bluetooth issue
    By inferno2469 in forum Operating System Optimization
    Last Post: 09-13-2006, 12:14 AM
  4. TinyXP Installation
    By swiftly93 in forum Centrafuse
    Last Post: 05-25-2006, 09:34 PM
  5. tinyxp rev04
    By hoodlum in forum WinNT Based
    Last Post: 05-16-2006, 01:15 PM
