Page 1 of 12 1234567891011 ... LastLast
Results 1 to 10 of 119
Thread: TinyXP Rev04 + FrontEnds
    Jan 2004
    NYC
    FYI for u guys, this was just released on the April. 14th
    http://www.retestrak.nl/Board/index.php?showtopic=13355
    ***UPDATE***
    Ok i played with this build over the weekend and so far so good...i currently have all this workin:
    - VIA M10K MotherBoard w\ all drivers(Video,LAN,Audio,4in1pack)
    - Hibernation
    - Road Runner[5-2 Build]
    - Wireless
    - WinTV FM drivers + FM APP[works in RR to]
    - USB-UIRT (w/Jenson IR20 remote)
    - Girder 4
    - Xenarc 700TSV TouchScreen Drivers
    - iGuidance 2.1.2NA
    - iGMod Preview 4*
    - WMP10*
    - Real\Quicktime Alternative*
    Current Install footprint 435MB [For Hibernation add 435MB + the amount of RAM installed in your carPC]
    The more things i test, ill update this thread
    ***INSTALL NOTES***
    -Required for WMP10[Regular Full Install] on this build-
    You need to install wmploc.dll to your sys32 directory. You can find this file HERE. Then download and install WMP10. Download it HERE
    -Required for Light Non-standard WMP-
    This package can install the Windows Media codecs. A second feature is that it can give you the ability to play Windows Media in your browser without the need to install Windows Media Player. Download itHERE
    -QuickTime Alternative-
    QuickTime Alternative will allow you to play QuickTime files without having to install the official QuickTime player
    Advantages compared to using the QuickTime Player:
    -Quick & Easy Install
    -Its easy to make a unattended installation
    -No background processes
    -Use a player of your own choice
    -Low on Resources
    -Small Size
    Download it HERE
    -RealPlayer Alternative-
    Real Alternative will allow you to play RealMedia files without having to install the official RealPlayer
    Advantages compared to using RealPlayer:
    -Proper Uninstallation
    -Low on Resources
    -No Advertising, No Registration forms, nothing annoying
    Download it HERE
    *newest install updates
    Low Bitrate ilyassx's Avatar
    Oct 2005
    Belgium, Denmark
    The link doesn't work, need to be signed in
    The old setup http://flickr.com/photos/ilyassx
    The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    PROGRESS:[########-]90%
    Jan 2004
    NYC
    This is the info about the new build *from the site listed above*
    eXPerience Presents...
    Windows TinyXP Professional SP2 Revision 04 Unattended CD
    This revised edition of TinyXP combines the small size of
    older versions, but with almost all of the functionality
    of later versions. This is primarily a fast gaming OS
    There are no Microsoft games in this edition.
    There are no third party programs included in
    this edition. You are however still able to open
    zip files, they will have a normal yellow folder
    but with a zip.
    There are no languages left apart from US English.
    The keyboard layout is United Kingdom, system locale and
    timezone are also set for the UK. This can be changed in
    Regional and Language Options in Control Panel - all
    "keyboard layouts" are left in.
    There are no networking command line tools - this increases
    security dramatically and stops businesses from using
    TinyXP for their networking. If you're running a business
    then hey - BUY WINDOWS XP. I have no sympathy with you
    people.
    It is important to note that TinyXP started out as a
    gaming OS that you can surf the net with, and use most
    programs with it. It ended up revised to the point that
    you might as well use normal XP. This however was always
    because it fully supported networking when it didn't need
    to for the purpose it was meant for - home use.
    In this edition, netstat.exe and other command line
    networking tools and a few more networking type features
    are now removed, TinyXP is back again to a very small
    footprint (365Mb), a very fast install (7 minutes) and
    uses far less RAM than Rev03 did - about 20Mb less.
    This edition has Internet Explorer included, (not just
    the core but the whole explorer). It also includes the
    DHCP service, Wireless LAN drivers and is still compatible
    with "Microsoft Office" and supports printers, joysticks,
    firewire etc.
    HINT: If you are in any doubt about the functionality
    of TinyXP Rev04 - get hold of a program called "VMware"
    and install TinyXP into VMware - this only takes about
    as long as an install on your real PC would.
    Then install "VMware tools" in VMware and drag whichever
    programs into VMware you need to install them and give
    the operating system a complete test before you actually
    use it.
    This edition DOES NOT work with "Sisoft Sandra".
    Sisoft Sandra seems to rely on a lot of Windows components,
    it was not worth the extra RAM and hard drive space needed,
    just to support Sisoft Sandra.
    This ISO is designed to be the ULTIMATE TinyXP, being
    very small and VERY fast, whilst still giving you the
    full functionality (almost) of normal XP - but without
    as many networking features.
    This edition does include "Active Directory" and basic
    networking between two PC's will work fine, as long as
    you enable "Simple File Sharing" under "Folder Options"
    in "Control Panel". This "Simple File Sharing" is
    disabled in this edition, so you can access the
    "Security" tab on your file and folder properties.
    EXE File Size in Bytes.......................... 127,774,258
    Extracted ISO File Size in Bytes............ 152,016,896
    Files on ISO........................................ 2,320
    Folders on ISO..................................... 86
    SHA-1 Checksum utility (fsum.exe) is provided with a
    batch script to check the EXE file and the ISO file.
    You must of course extract the ISO file from the EXE
    file to check the ISO checksum!
    The checksum codes for both the EXE file and the ISO file
    can be found at...
    Look under the section called Releases Only (P2P) and find
    the thread for TinyXP Rev04.
    If any of the above sizes, file & folder totals, or SHA-1
    checksums are different to what you have, DO NOT USE THIS
    EXE OR ISO FILE! You have a fake (repackaged) eXPerience
    release! Most probably repacked with a trojan, or other
    malicious worm/virus/rootkit.
    Windows Performance Info...
    Operating System RAM Memory Usage = 45Mb (▒ 5Mb)
    WINDOWS Folder = 366.2Mb
    Running Processes on First Install = 14
    Install Time for Windows = Seven Minutes
    Windows XP Pro Custom Added Features
    eXPerience Spectrum Wallpaper
    Integrated Service Pack 2 (WindowsXP-KB835935-SP2-ENU.exe)
    Registry Tweaks For Performance/Gaming/Internet
    Windows Media Center 2005 Beta Version Theme (Royale)
    Integrated Critical and Recommended Post SP2 Hotfixes
    (Windows Updates) up to 28th March 2006...
    IE6.0sp1-KB905915-Windows-2000-XP-x86-ENU
    WindowsInstaller-KB893803-v2-x86
    WindowsXP-KB873333-x86-ENU
    WindowsXP-KB873339-x86-ENU
    WindowsXP-KB883939-x86-ENU
    WindowsXP-KB884020-x86-enu
    WindowsXP-KB885222-v2-x86-ENU
    WindowsXP-KB885250-x86-ENU
    WindowsXP-KB885835-x86-ENU
    WindowsXP-KB885836-x86-ENU
    WindowsXP-KB886185-x86-enu
    WindowsXP-KB886677-x86-enu
    WindowsXP-KB886716-v2-x86-ENU
    WindowsXP-KB887472-x86-enu
    WindowsXP-KB887742-x86-ENU
    WindowsXP-KB887797-x86-enu
    WindowsXP-KB888113-x86-ENU
    WindowsXP-KB888240-x86-ENU
    WindowsXP-KB888302-x86-ENU
    WindowsXP-KB889527-v3-x86-ENU
    WindowsXP-KB890046-x86-ENU
    WindowsXP-KB890175-x86-ENU
    WindowsXP-KB890859-x86-ENU
    WindowsXP-KB891781-x86-ENU
    WindowsXP-KB893066-v2-x86-ENU
    WindowsXP-KB893086-x86-ENU
    WindowsXP-KB893357-v2-x86-ENU
    WindowsXP-KB893756-x86-ENU
    WindowsXP-KB894391-x86-ENU
    WindowsXP-KB894395-x86-ENU
    WindowsXP-KB896344-v2-x86-ENU
    WindowsXP-KB896358-x86-ENU
    WindowsXP-KB896422-x86-ENU
    WindowsXP-KB896423-x86-ENU
    WindowsXP-KB896424-x86-ENU
    WindowsXP-KB896427-v3-x86-ENU
    WindowsXP-KB896428-x86-ENU
    WindowsXP-KB896626-v2-x86-ENU
    WindowsXP-KB898461-x86-ENU
    WindowsXP-KB898900-v2-x86-ENU
    WindowsXP-KB899587-x86-ENU
    WindowsXP-KB899589-x86-ENU
    WindowsXP-KB899591-x86-ENU
    WindowsXP-KB900725-x86-ENU
    WindowsXP-KB900930-x86-ENU
    WindowsXP-KB901017-x86-ENU
    WindowsXP-KB901190-x86-ENU
    WindowsXP-KB901214-x86-ENU
    WindowsXP-KB902400-x86-ENU
    WindowsXP-KB903234-x86-ENU
    WindowsXP-KB904706-v2-x86-ENU
    WindowsXP-KB905414-x86-ENU
    WindowsXP-KB905749-x86-ENU
    WindowsXP-KB905915-x86-ENU
    WindowsXP-KB908519-x86-ENU
    WindowsXP-KB908521-x86-ENU
    WindowsXP-KB910437-x86-ENU
    WindowsXP-KB911927-x86-ENU
    WindowsXP-KB912919-x86-ENU
    WindowsXP-KB913446-x86-ENU
    Enjoy this fine release from eXPerience
    Build Date: 13.04.2006
    Release Date : Spring 2006
    Oct 2005
    Belgium, Denmark
    Quote Originally Posted by camsgs3
    Here is the link to DL,
    of later versions. This is primarily a fast gaming OS.
    but with a zip.
    people.
    firewire etc.
    use it.
    can be found at...
    Good but you have to remove the torrent link (offence to Forum Rules)
    Cheers,
    512 DDRII 533
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    Jan 2004
    NYC
    removed, if u didnt get it.. just sign up at the site
    Oct 2005
    Belgium, Denmark
    Thanks man, i will
    512 DDRII 533
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    Jan 2005
    i tried it and installed frodoplayer
    but it didn't work because it could'nt connect to database
    it has something to do with MBAC, that is missing
    i would also like to now if its possible to hibernate in versions of tinyxp
    anyone??
    Oct 2005
    Belgium, Denmark
    Not tested yet
    512 DDRII 533
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    Dec 2005
    Australia
    Well I just tried it with RR. It works, although I had heaps of problems trying to install drivers. Even got a BSOD. Touch screen wan't detected )might be due to driver problems) and there IS NO HIBERNATION. This is a deal killer for me. I was hoping to see real fast resuming.....Oh well.
    Jan 2004
    NYC
    Quote Originally Posted by wilsonj
    ahhh that sucks,does anyone know if we can add it to this build?
  1. hibernating in tinyxp
    By @rie in forum Operating System Optimization
    Last Post: 02-04-2010, 10:58 PM
  2. TinyXP Rev04 + FrontEnds THREAD GONE..
    By camsgs3 in forum Operating System Optimization
    Last Post: 11-13-2006, 07:14 PM
  3. TinyXP bluetooth issue
    By inferno2469 in forum Operating System Optimization
    Last Post: 09-13-2006, 12:14 AM
  4. TinyXP Installation
    By swiftly93 in forum Centrafuse
    Last Post: 05-25-2006, 09:34 PM
  5. tinyxp rev04
    By hoodlum in forum WinNT Based
    Last Post: 05-16-2006, 01:15 PM
