Results 1 to 3 of 3
Thread: Problem reinstalling Windows XP
    May 2006
    I have been running this computer for over a year without a problem. Then I decided to activate the Fax Services Component for Windows. During the activation process I received a message to insert the Windows disk. I did this and shortly I received the following message:
    "Setup cannot copy the file fxservent.dl_"
    I click cancel and ended the program. I then tried to run the install program again. The same thing happened. Except this time the message said:
    "Setup cannot copy the file fxsperf.in_"
    I again clicked Cancel. I decided I would reinstall Windows and try to repair the program. I put the Windows CD in and booted from the CD. During the reinstall/repair I received this message:
    "Setup cannot copy the html32.cn_ file"
    I canceled the reinstallation/repair and now need help.
    I am running Windows XP Professional SP2 with all of the updates current. What can I do to fix this problem?
    Elsewhere
    Try cleaning your WinXP CD first and check to see if it's scratched up.
    How about the Wiki?
    Sep 2005
    UK
    could try copying the I386 directory onto your hard drive using a boot floppy/usb key then run winnt from that directory, setup should run entirely from the hard drive that way
  1. VS6 and Windows XP - Install problem
    By InHoc in forum Coders Corner
    Last Post: 10-15-2006, 07:31 PM
  2. Wifi, windows XP, frodoplayer
    By omehegan in forum FrodoPlayer
    Last Post: 08-22-2005, 06:14 PM
  3. Strange windows XP problem!
    By Dylan Jones in forum Newbie
    Last Post: 04-01-2005, 11:52 AM
  4. PowerMate on Windows XP Embedded
    By JasonSurratt in forum Input Devices
    Last Post: 01-14-2004, 12:06 PM
  5. Adding "Sound Events" to Windows XP...
    By Defiler in forum Software & Software Development
    Last Post: 03-13-2002, 10:59 AM
