+ Reply to Thread
Results 1 to 10 of 13
Thread: HOWTO: modifying the boot,welcome, and logout screens
    Newbie JimmBrooks's Avatar
    May 2006
    Exclamation HOWTO: modifying the boot,welcome, and logout screens
    PLEASE DONT POST ANYTHING HERE THIS IS A HOWTO ONLY!!! POST YOUR QUESTIONS FOR ME HERE~>
    BootScreens,WelcomeScreens, Signoff Screens
    CHANGING THE BOOT SCREEN
    First off to accomplish these feats you are going to need to have these three programs....Boot skin, logonstudio and photoshop.
    The reason i chose these programs short of ps, for obvious reasons, is because they simply change what bmp file your computer uses in the ntoskrnl file instead of modding the file, you change the bmp. So the file behaves as if it did from the initial loading of windows. This allows it to be completely reversable as well as not having to do safemode changes. Plus the system resources dont change for those of you using a smaller version of xp.
    step 1
    After downloading and installing the two programs short of photoshop open up boot skin. You will see a few already premade designs. Any of the ones you click on there will also be a button that says preview so that you can see what it will act like when loading.
    step 2
    It is now time to create your own boot screen. In your photoediting program of choice. open up a new doc that is set to what ever pixel ratio you want,(native boot size is 640 x 480) along with to make sure you set it on windowsOS and 4bit 16color palete. now this is where you creative or lack of juices start flowing. Make it simple to start because replicating more than 16 color picture in 4bit mode doesnt lend itself to be a masterpiece. Start easy and see from there. Keep in mind you are going to have to make two pictures. One for the background and one for the loading bar. The loading bar is natively (22 x 9 ) <~ not much room for anyting to creative.
    step 3
    Time to create the ini file that is going to take your two pictures together and make them work. Here is the coding for my nissan one.
    [BootSkin]
    Type=0
    Name = "Shift"
    Author = "Jimm Brooks"
    Description = "nissan CARPUTER"
    ProgressBarX = 225
    ProgressBarY = 325
    ProgressBarWidth = 200
    where anything in brackets or quotes is for reference only. The progress bar file is the loading bar picture you made. the x and y location is exactly that how far x and y the bar will show up on your picture. and the width is how long you want your bar to move before making another pass from left to right.
    and your screen is the backgroung immage you made.
    step 4
    time to implement your creation Go to where you installed the boot skin program usually c: programfiles / stardock / wincustomise / bootskin / skins
    create a new folder in there named what ever you want it to be called. Copy your two pictures that are in bmp format into the folder as well as the ini file you created. once that is completed you will close that window and open bootskin the program. Wallah you now see your custom skin you made and can preview it as mentioned in step 1. If you do not like where your progress bar is located simply modify the x y coordinets in the ini file untill its where you want.
    IF I AM MAKING A SCREEN FOR YOU I WILL SEND IT TO YOU IN A SINGLE FILE FOLDER THAT YOU JUST COPY INTO THE SKINS FOLDER
    ....Modifiying your welcome and logout screens next.
    Low Bitrate Cruelkix's Avatar
    May 2006
    Denver, CO
    Hey,
    The BootSkin prgram that you use in this thread does not appear to accept any resolution other than 640 x 480. Is this true? It seems the only way I can get the prgram to recognize my skin is by using that res.
    Maximum Bitrate yrean's Avatar
    Apr 2006
    Chicago
    that is a windows issue. it only allows that size i believe
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
    May 2006
    Denver, CO
    Yeah , thats what I thought ... Sorry about posting in this thread. Can an admin delete them please?
    _
    Mar 2004
    Little Elm, Texas
    JimmBrooks - your thread is great. While following it, I ran into a few little problems. So I did a bit of searching to try and find some more info, and I came up with this link:
    http://www.wincustomize.com/articles.aspx?aid=58737&c=1
    It helps to clarify a few things.
    I now have my own boot screen!
    Much props to you for taking the time to work on something like this!
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    any updates for welcome screens?
    I'm sure you're a busy guy, just thought I would see if you might have written it just not gotten it posted yet?
    Jan Bennett
    Newbie xcalibur's Avatar
    Apr 2006
    Ontario
    hey boes anyone know how to make a bootscreen show up at 640 x 480.. or even change the default hertz cause my monitor is really picky
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    bios
    Sep 2006
    The intarwebs
    i made a mazda bootskin quite a long time ago.
    here it is
    May 2005
    Germany
    Ti-ejtsch
+ Reply to Thread
