Results 1 to 4 of 4
Thread: Best way to create an image of disk for backup
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    I have finally got an install which works well for me, based on TinyXP v4. Boot time isn't great so I still want to "tinker", but this gives me a problem. I have two partitions set up, the primary is FAT32 and the other is NTFS !
    Before I moved to the NTFS format, I used to use Knoppix, to create a full workable copy, and then go back to windows and burn the files to a CD.
    Can any of the ISO burners do an image copy that can be restored if required if any of my tinkering goes wrong.
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Elsewhere
    I use Symantec Ghost.
    How about the Wiki?
    Dec 2003
    West Midlands
    Thanks for the response DP, i have been looking to see if I can get the full image on a Bart PE disk. I will let you know how I get on.
    cheers
    KPJ
    Dec 2003
    West Midlands
    Well, I have downloaded BartPE from www.nu2.nu, and created with my OS and SP2 disks at the ready, I created my bootable CD image, which came out at around 150Mb. This boots an XP environment from the CD, which will read and write NTFS volumes.
    Once booted, I copied all files in drive c: to drive d:\backup. I then had to copy this image onto my laptop which had the PEBuilder setup on it, and using UltraISO added the backup files to the PE boot disk.
    This gave me a boot disk with my install on it, minus the hiderfil.sys and pagefil.sys.
    Sorted !
    KPJUK
  1. Help w/ backup, restore, or image drive/disk for recovery
    By ITL in forum Software & Software Development
    Last Post: 10-25-2005, 08:33 AM
  2. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 10:24 PM
  3. Bug Reports
    Last Post: 10-16-2004, 12:25 AM
  4. Hard Disk Controller / make HD-in-car safer
    By SverrirOrn in forum General Hardware Discussion
    Last Post: 09-23-2004, 12:01 AM
  5. Replies: 3
    Last Post: 08-14-2003, 08:18 AM
