Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Ram issues
  1. #11
    May 2006
    F**K oh well i might as well just spend 90 on a gig. do you kow anything bout tft i'm having issues. its hella blurry. and i dunno what to do.
  2. #12
    Mar 2006
    Colorado, but Canadian!
    There are lots of lcd's that have a blurry image. I have yet to find a cure. We tried on this thread though: 7" Xenarc extremely blotchy video
    As for the RAM, it could be because it is Dual something RAM. I forgot the name of it, but it is the "high density" stuff that alot of boards won't recognize. Therefore you only get half, which is what you are getting. Try a non-dual layer.
    1.9in x 2.9in -- 47mm x 73mm
  3. #13
    May 2006
    on your setup do you have the display settings as lcd or tv thanks
  4. #14
    Mar 2006
    as lcd.
    for tv, it uses RCA, and that is very very blurry.
  5. #15
    May 2006
    so how do you have your lcd plugged through the vga port. because my screen only has rca ports. thanks
  6. #16
    Mar 2006
    then you bought the cheapo display that is not VGA to save a couple bucks. that means the best resolution you can get is tv quality which is pretty crappy.
    only thing to do without getting a new screen, is making the dpi bigger under the display settings. its still going to be fuzzy reading text.
    the screen is something that should never be overlooked. its the only part that should be seen on a regular basis!
  7. #17
    May 2006
    well i guess il be selling it and invest ona touchscreen
  8. #18
    May 2006
    you know where i can find a indash touch screen for under 200
  9. #19
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    If you are talking flip out VGA touch screen...not really. If you are talking about a flat mount vga touch screen then perhaps used on eBay. (Where I got mine super cheap)
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
  10. #20
    Mar 2006
    ebay. probably used though...
  1. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 07:39 PM
  2. Having instability issues with your M7NCG 400 and/or XP install?
    By wallaceacura in forum General Hardware Discussion
    Last Post: 07-20-2005, 01:29 AM
  3. FS lots of ram
    By kderedwolf in forum Classified Archive
    Last Post: 04-29-2005, 06:28 PM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
  5. Replies: 1
    Last Post: 04-30-2004, 07:04 PM
