Results 1 to 10 of 20
Thread: Ram issues
    May 2006
    Ram issues
    so i just got my carputer and installe dmy 1gb pc2100 ram but in tinyxp rev 4 it only reads that there is 499 mb is there a driver that i need to install i hvae a via mobo
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    doesnt sound like a driver issue, what does the bios report as the ram size? It could easy be half the stick isnt working.
    Elsewhere
    It's more like the motherboard shares system RAM for video RAM.
    How about the Wiki?
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    I know this sounds like a dumb question but what speed of ram does your PC take? I've put slower ram in a PC with a faster bus speed and it registers as half.
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
    May 2006
    mother boeard takes up to 1 gb. but it wouldnt take 500 mb for vedio.
    Mar 2006
    Colorado, but Canadian!
    no but it could take up to 256mb on via mobos. I say do as scimtar suggested and look when it post's to see how much ram is being registered at the simple level. make sure you disable quick boot too so that it actually scans the ram and doesnt just assume what it is (saves time, hence quick boot!). if in the post it says 1024mb, then obviously software related. I know that in 98, it only supported 512, even though a 4gb stick could be in there. Could be a driver. If it does not show up at booting, then run memtestx86. (its called something like that). its free and will check your ram. good luck.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    how do i change my bios settings
    form quick to normal.
    May 2006
    nm found out how.
    May 2006
    well hte bios says its only 491mb is it possible that this is caused by the fact that it is a cheapo ram off of ebay high density.
    Mar 2006
    Quote Originally Posted by allahsone
    Yup. That can do it...
  1. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 07:39 PM
  2. Having instability issues with your M7NCG 400 and/or XP install?
    By wallaceacura in forum General Hardware Discussion
    Last Post: 07-20-2005, 01:29 AM
  3. FS lots of ram
    By kderedwolf in forum Classified Archive
    Last Post: 04-29-2005, 06:28 PM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
  5. Replies: 1
    Last Post: 04-30-2004, 07:04 PM
