Results 1 to 9 of 9
Thread: Can't transplant new windows hard drive?
    May 2006
    I installed windows and everything for my car computer with the hard drive hooked up to my desktop, so that I wouldn't have to sit out in the car and set all of it up on the 7" screen. When I go to take the hard drive and put it out in the car computer, it never loads windows. It worked fine on my desktop, but in the car it won't load. Is there something that prevents you from transplanting a recent windows installation hard drive to another system?
    Low Bitrate lcaruca97's Avatar
    Jun 2004
    Quad Cities Il.
    you aren't serious are you?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    It had better be the exact same setup to transplant like that. Like same motherboard, graphics card, processor, way that things are plugged together. Windows installs things called drivers, and if you're using Windows XP, the boot drive better not change location (primary/secondary, master/slave). If any of this is different between your two machines, you may see issues.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    The windows install process sets drivers based on what hardware is present. Mostly this means install on the system that the drive will be used for.
    TruckinMP3
    Read the FAQ!
    Elsewhere
    Quote Originally Posted by TDIGPS
    Yeah. It's caled Windows!
    How about the Wiki?
    Maximum Bitrate DeltaFX's Avatar
    France
    Maybe that's an xp feature, dunno. Such transplant work fine with 9x install : last week I hooked the "Huge-1083-MB-DD" of my ancient laptop P133, housing win95a to my Kx7-333 +tbird 1.4ghz+Gef4... Curiously it booted fine, then asked for its win95cd for drivers.
    Now Galileo is real. Muhahahahaha :p
    Elsewhere
    Actually, it's any NT-based OS, which includes NT4.0, 2000, XP and all server variants.
    It has to do with the Hardware Abstraction Layer, which contains information about the hardware on the computer that Windows references. If the hardware doesn't match the HAL, you've got problems, plain and simple.
    XP takes it a step further by tying the licensing into the contents of the HAL.
    How about the Wiki?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Take it back to the original PC.
    Go to device manager, change the ATAPI driver to standard.
    go to display properties, revert the resolution to 640x480 or 800x600 abd try again.
    the main problems with switching harddrives between machines is the IDE drivers are different and sometimes the video drivers. The other drivers don't really matter.
    NB this doesn't work in all cases.
    Mar 2006
    Colorado, but Canadian!
    Well, do you mean it POST's and shows the HD, or just stays off??? Usually with the windows transplanting thing, I've never had a problem as long as you do a full install. The only thing is Windows yells at you, and you have to reactivate the copy because its basically a new computer. I would check cables, your dc-dc PSU, and connections.
    1.9in x 2.9in -- 47mm x 73mm
  1. Hard drive upgrade problems :-(
    By Arex in forum General Hardware Discussion
    Last Post: 04-29-2006, 01:53 PM
  2. MB870 & Slimline Floppy Drives
    By McGreggor in forum General Hardware Discussion
    Last Post: 11-09-2005, 07:32 AM
  3. Stop Press: Faulty Hard Drive Fails to Work
    By phatbenny in forum General Hardware Discussion
    Last Post: 12-23-2004, 06:36 PM
  4. Hard Drive Mounting / SAVE the drive!
    By DerekR in forum General Hardware Discussion
    Last Post: 03-11-2004, 09:07 PM
