Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Windows Vista Beta... sleep?
  1. #11
    Sep 2005
    Pomona, CA
    I may have to install a RC build in my car sometime to try out the Sleep feature and see if it really does what it says it does when the PSU does the hard off.
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  2. #12
    May 2006
    Seattleish, WA
    Quote Originally Posted by fatejd View Post
    ??? Are you talking about Vista actually surviving the sequence of sleep, power off, power on, wake?
    :: Mark
  3. #13
    Sep 2005
    Pomona, CA
    Well, from what I understand (and I just tested it on a box) is that Sleep keeps you computer on like Standby, but if you lose power it will resume like Hibernation. However, from my single test (I put it to Sleep and unplugged the power) it doesn't work - I plugged it back in and booted up and it booted like a normal startup. Do I misunderstand the functionality here?
    Carputer Progress:
    Teardown PC [100%]
  4. #14
    May 2006
    Seattleish, WA
    Umm, you may have drank too much of the KoolAid over there.
    I agree that Vista is supposed to do what you've been reading, but I've never seen it work right. I've only ever seen it work as XP does now, which is what you're seeing in the lab.
    Technically, Sleep is a low-power keep RAM alive mode; it's still drawing power. Hibernation is the flush-to-disk. What you're hoping for is the hybrid mode, which is where it does the flush of hibernate, then sleeps. _In theory_ the hibernate file should catch on next boot if the machine loses power.
    oops.
    :: Mark
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 04-12-2012, 08:29 PM
  2. Replies: 33
    Last Post: 05-07-2008, 10:24 PM
  3. Replies: 2
    Last Post: 04-06-2006, 11:07 AM
  4. Bare essentials for bootup
    By Psychobiker in forum Operating System Optimization
    Last Post: 01-05-2006, 05:08 PM
  5. Will leaving Windows in Standby drain battery?
    By slffl in forum Power Supplies
    Last Post: 08-03-2004, 10:57 PM
