instead of changing rdisk, try changing disk
hi
does anyone know how to get ewf running on a second drive?
I'm booting from CF and want to run some stuff from a USB drive too. I've tried copying the reg keys from the Protected\volume0 reg key to Protected\volume1 and changing the rdisk from 0 to 1 but that hasn't worked.
Any ideas?
cheers
Danny
your computer is bored - give it something useful to do!:rosetta@home
doesn't seem to be working - when I try ewfmgr d: it gives me error 50. I'm using the hitachi fixed disk driver for the usb drive if that makes a difference?
Do I need to change anything here apart from disk(0) to disk(1)? Should I copy the [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\LEGACY_EWF\0000] key to make a 0001?
"Service"="EWF"
"Legacy"=dword:00000001
"ConfigFlags"=dword:00000020
"Class"="LegacyDriver"
"ClassGUID"="{8ECC055D-047F-11D1-A537-0000F8753ED1}"
"DeviceDesc"="EWF"
"Capabilities"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\LEGACY_EWF\0000\Control]
"ActiveService"="EWF"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\ewf]
"ErrorControl"=dword:00000001
"Group"="System Bus Extender"
"Start"=dword:00000000
"Type"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{71A27CDD-812A-11D0-BEC7-08002BE2092F}]
"UpperFilters"="Ewf"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\ewf\Parameters\Protected\Volume0]
"ArcName"="multi(0)disk(0)rdisk(0)partition(1) "
"Enabled"=dword:00000000
TIA
Danny
