Results 1 to 10 of 10
Thread: Adding components (modem support) that were removed on nlite install to current XP
    FLAC ppgt94's Avatar
    May 2001
    USA
    Ok, here's the deal. A few months ago I made what I thought to be the perfect custom XP install using nlite. At the time I thought I'd never need dial-up modem support in the car. That was all fine and dandy until I wanted to use my LG-235 as a modem via bluetooth.
    I know the phone will pair with the BT dongle and have connected to the Internet using the phone as a modem on my laptop with a OEM XP install.
    I know according to nlite's FAQ say you can't really add a component once it's been removed. Supposedly the only way to do such a thing is to import a previous session to further refine the selections made in that previous session to include what you removed. Then of coarse I would presume that would call for a re-install of the entire newly modded OS
    So does anyone know of a method/hack to add this dial-up modem support into my current very stable and highly personalized XP install? All my 'net scouring left me mostly empty handed and discouraged. I'm holding out for a mp3car hero to save the day. ....Please?
    May 2001
    USA
    Bump?
    Nov 2005
    Couldn't you just install the driver from the install CD that came with the phone (or the latest updated version from the website)?
    or use the add hardware wizard and select the driver if it still works on your install?
    your computer is bored - give it something useful to do!:rosetta@home
    May 2001
    USA
    Quote Originally Posted by dcdc
    Normally, I could but it's like windows doesn't even know what a modem driver is.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Oh man. Me thinks you're scr3w3d. The only suggestion I have is to try "add / remove hardware" If thats even in your nLite build.
    Actually some more suggestions are comming as I'm typing this. What does the device show up as in System?? If it's showing up as unknown you may have a chance. Try selecting the modem's .inf file from system.
    If I remember correctly though most nlites posted (including the one I created and I think was modifed a few times) takes out modem support... You might have to slipin the drivers on a new nLite plus enable modem support... it might be quicker to re-build an nLite.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Could always build a new cd with nLite then run a repair on your current XP install... maybe you wouldn't loose much.
    Tidder
    Try RevFE
    Nov 2005
    or if that fails, create a new nlite CD with modem support, and then install that and your original onto different partitions and compare the registry differences and file differences between them with a 3rd party app. The modem support entries should be the only differences...
    Beyond Compare is excellent for comparing directories.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by Tidder
    If you still have your sessions file, you can recreate the nlited OS.
    There is no way to add it, even with the control panel. I know cause I tried with the exact same thing. I was using TinyXP, but couldn't get my Blackberry to work because it removed the modem.
    Good Luck.
    Michael
    Nov 2008
    install mdmgen.inf
    I had the same problem, but after installing mdmgen.inf I was able to see a modem.
    link: http://www.infdump.com/inffiles/M/mdmgen.inf
    Variable Bitrate shrinkydinx's Avatar
    May 2005
    Quote Originally Posted by nstream View Post
    one know if this 1-post user's advice is correct?
    carputer - done.
  1. Safe nLite setting.ini
    By IntellaWorks in forum WinNT Based
    Last Post: 02-03-2010, 05:41 AM
  2. XP System Builder
    By SFiorito in forum WinNT Based
    Last Post: 03-19-2007, 05:13 AM
  3. Why can't I install windows XP ? please help ?
    By shinjetko in forum Newbie
    Last Post: 09-19-2006, 02:02 PM
  4. Tinyxp vs nlite vs sensible install
    By geeky_hawkes in forum WinNT Based
    Last Post: 06-15-2006, 03:55 PM
  5. Tech Support Calls
    By Rafster in forum Off Topic
    Last Post: 06-12-2006, 11:49 AM
