View Poll Results: Nilte vs Hibernate full XP
Voters
16. You may not vote on this poll
  • nLite
    8 50.00%
  • Full XP WITH Hibernate
    8 50.00%
Results 1 to 10 of 11
Thread: Keep nLite or Do regular install w/ hibernate?
    Apr 2005
    Queens, New York
    Well I have been having lots of problems with my nLite install from thing not working and what not also, my usb devices must be plugged into the same port they were installed on..... So my question is should i keep the nlite install and do another nlite or do a full xp install and just use hibernate?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    FLAC SFiorito's Avatar
    May 2004
    3rd Option: redo your nLite install but being more careful of what you remove....
    was Boston -> now Canada!
    Been there with nLite. Had a good working system which would ocassionally give me problems which I couldn't figure out if it was nLite or not. I've since done a full install and manually stopped services I don't use and I never looked back.
    I have a 12K with a full install of XP using Hibernate and I no longer have these strange issues. The time it takes to get it right with nLite just was not worth it. With the install now all I have to do is turn on a serive if it's needed later on. It's much easier to add to it later with a full install and the boot up time is really not much of a difference to make it worth it IMHO; but what the hell do I know
    Chuck
    FLAC sama's Avatar
    Feb 2006
    London, UK
    why not use TinyXP?
    Apr 2005
    Queens, New York
    Quote Originally Posted by chuckster
    Chuck
    What about the hibernate and resume problems? Are those fixed?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Newbie Howie's Avatar
    Jun 2006
    Adelaide, Australia
    I've just reformatted going from Windows XP Pro to TinyXP Rev 4.0 to Windows MCE 2005 and now i'm back to Windows XP Pro. I've switched a whole heaps of services and uninstalled alot of bloatware that comes with windows, and i'm reasonably satisfied with it's performance and at least it's easier to debug problems.
    Progress: 50% [▓▓▓▓▓▓▓▓▓▓----------]
    Athlon 1200 M-Atx
    usb-wifi, usb-gps, usb-tuner, usb-bluetooth
    Quote Originally Posted by Cheekz185
    I no longer have any hibernate and resume issues. I use this function many times a day and it has worked without any problems. I had many issues when using nLite and the other pieces which supposedly are designed to speed things up.
    I like Howie am using XP Pro and just adjusted services removed the bloat manually. I have no problems with running anything I want now.
    Chuck
    Apr 2005
    Queens, New York
    Should i still use minlogon if i decide to install a full version of XP? Should i put MCE or Pro? Will minlogon cause any problems?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Jul 2006
    Just a quick Q- I dont mean to hijack....
    Will Minlogon and EWF work with TinyXp?
    Nov 2005
    CT
    Quote Originally Posted by PeteP. View Post
    Yes
  1. 2003 Ford Ranger FX4 Install (Lots of pics)
    By tbird2340 in forum Show off your project
    Last Post: 10-12-2009, 10:21 AM
  2. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 03:41 PM
  3. Resume after hibernate scrutinized
    By ldave in forum PowerVoice
    Last Post: 02-09-2006, 11:04 PM
  4. nLite = no logical disk mgr service?
    By JW™ in forum WinNT Based
    Last Post: 05-13-2005, 08:57 AM
  5. Carputer install
    By H3nrY in forum Newbie
    Last Post: 07-25-2004, 09:45 AM
