Results 1 to 10 of 10
Thread: okey.. i gave up.. need help tinyXP
    Dec 2005
    i need help to install tinyXP
    i know.. im a n00b.. i wasnt gonna post it but.. well.. guess i need help..
    i did search and tried like 10 days to install tinyXP.. but i still cant
    plz dont give me 'search u noob.. blah blah blah..' i tried my best and with my limited basic computer skill.. its not gonna work.. but i want it
    have P3 651MHz 256RAM laptop which had win98 originally
    it had XP installed (by my bro long time ago i think) and i tried install tinyXP and its all f***ed up..
    i burned tinyxp.iso or winXP.iso to CD and it did boot from CD
    half way done.. after reset, i was getting those error msg everytime
    Error:
    Installation failed E:\I386\asms
    Error Message: Data Error (Cyclic Redundancy Check)
    Fatal Error:
    One of the components that windows needs to continue setup could not be installed.
    i tried for a week and i finally installed it (just winXP)
    booted with win98 booting disk, format harddrive, and winnt.exe in i386 folder
    took me a week to install winXP back.. yes.. i did it..!
    now.. tinyXP..
    it doesnt have winnt.exe in i386 folder.. so i cant install it with my only solution - run winnt.exe in DOS
    whenever i tried it (boot from CD), im getting same error msg
    so can someone help me? please...
    Aug 2006
    sounds like you either have a bad burn or your drive doesn't like the disk... If you can transfer the writer that cut the disk over to your new car pc setup for the install....
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I tried pretty hard with Tiny XP to get it to work with my CARPC, never was really satisfied. Seemed it was allways lacking a capability I wanted. Anyway long story short, I have found a solution to most of my problems with it.
    First get your burned copy of tinyXP, lay it on the floor and begin to smash it with a hammer and when you are done. SMILE, you will feel a lot better and never have to worry about trying to install it again.
    I hope this helps...
    New Age Garmin - Skin for RR
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by MIQ228 View Post
    Error:
    Fatal Error:
    now.. tinyXP..
    The developer has a website and forum. If you search there, you will find that there is a way to make a very specialized version for yourself. Basically, you just edit a long list of windows "parts" to remove those that you DO NOT WANT installed. You then insert a good, full version of XP, and run the guys program, and it creates, and burns the ISO for you. Worked perfectly for me.
    Michael
    Variable Bitrate vladcarpc's Avatar
    Nov 2006
    Sao Paulo, Brazil
    Quote Originally Posted by Wiredwrx View Post
    What is the site URL? Thanks
    \/ |_ /\ [)
    1995 Civic Sedan EX
    CarPC status: [||||||||||||] 100% - Phase 1 Complete!
    YouTube video - WorkLog
    Mar 2007
    you already have xp cds correct? Then all you need is a software called nlite to create your own version of tiny xp.
    Nov 2006
    Sao Paulo, Brazil
    Currently downloading TinyXP via torrent. Will also try the nlite. Thanks.
    \/ |_ /\ [)
    1995 Civic Sedan EX
    Dec 2006
    Hello everybody,
    I had the same problem. Just put a normal xp cd in the drive and reboot.
    The setup will restart and the error will not come anymore. Change the cd again to the Tinyxp cd just after one or two minutes after the setup restartet.
    Doesnt matter what kind of xp cd you use. I had Tinyxp Rev 06 and used Xp cd service pack 1 German.
    Regards
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Quote Originally Posted by ThunderStick View Post
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
    Apr 2005
    Long Island, NY
    even two years later ... this did the trick
    thanks
  1. nLite v. TinyXP
    By RedGTiVR6 in forum Operating System Optimization
    Last Post: 02-15-2008, 08:03 PM
  2. Error.log when running 1.7 on TinyXP rev.4
    By urosbe in forum Centrafuse
    Last Post: 02-06-2007, 04:53 PM
  3. TinyXP bluetooth issue
    By inferno2469 in forum Operating System Optimization
    Last Post: 09-13-2006, 12:14 AM
  4. TinyXP Rev04 + M10k drivers = ???
    By Gearhead61 in forum WinNT Based
    Last Post: 07-06-2006, 11:28 AM
  5. SqueezeBox and TinyXP REV4
    By blkwrx in forum Operating System Optimization
    Last Post: 06-21-2006, 03:29 PM
