Results 1 to 8 of 8
Thread: XP on a flash card
    Sep 2006
    Cornwall, England
    XP on a flash card
    Is it possible to install XP on a compact flash card and make it read-only and use the hard drive for swap files etc. or do you have to use Windows XP embedded to make an image file for the flash card. I have heard that Windows embedded is a very tricky program to use.
    Thanks for any help
    Craig
    Elsewhere
    Yes, it's possible.
    If you search the forums here, there is a tutorial.
    How about the Wiki?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Yup, very tricky to use.
    If you're going this route, forget the swap file altogether. Just use enough ram that you shouldn't have to worry. When I had my sys setup in Read Only, I didn't use a swap at all. I have 512mb ram, seems to be fine. Could watch movies, cruise the internet, play music, etc.
    Look for threads started by SFiorito.
    Tidder
    Try RevFE
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    just remember that flash cards have a limited number of read / write cycles, therefore eventually it will fail.
    I used some for an embedded pc for work a while ago and had to replace them all within 6 months, i'd go with DiskOnChip, thats what i replaced the flash with. Yes it is still a type of flash but more durable.
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by pate60 View Post
    Not read/write cycles, thought it was just write cycles. Hence the read-only.
    Tidder
    Try RevFE
    Nov 2005
    CT
    Jun 2004
    could be cant remember.
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
  1. Installing carputer on a flash card?
    By hunka27 in forum General Hardware Discussion
    Last Post: 12-28-2005, 08:36 PM
  2. Run WinCE & XP together
    By ShawJohn in forum Software & Software Development
    Last Post: 11-07-2005, 06:09 PM
  3. booting from flash card faster than HD?
    By ecolner in forum Newbie
    Last Post: 02-24-2004, 02:36 PM
  4. Iomega 340mb microdrive Compact Flash card for $68
    By pdpshaggy in forum Classified Archive
    Last Post: 05-11-2002, 04:31 AM
  5. help - video card problems
    By Cliff in forum General Hardware Discussion
    Last Post: 04-15-2002, 06:25 PM
