Trying to make tiny xp from my Windows XP Disc with nlite
I used the Tiny XP Guide from exPerience, and I keep getting this message in nLite, what am I doing wrong here? I'm using WinXP service pack 2 disc home edition.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: Cannot create a file when that file already exists.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.__Error.WinIOError()
at System.IO.FileInfo.MoveTo(String destFileName)
at ..()
at ..(Object , EventArgs )
at System.Windows.Forms.Control.OnEnter(EventArgs e)
at System.Windows.Forms.Control.NotifyEnter()
at System.Windows.Forms.ContainerControl.UpdateFocuse dControl()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
nLite
Assembly Version: 1.2.0.1
Win32 Version: 1.2.0.1
CodeBase: file:///C:/Program%20Files/nLite/nLite.exe
System
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
nLite
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
cablib
Assembly Version: 1.0.2459.36134
Win32 Version:
CodeBase: file:///C:/Program%20Files/nLite/cablib.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINNT/system32/msvcm80.dll
nlgw
Assembly Version: 1.1.0.0
MCDBNET2
Assembly Version: 1.32.0.0
Win32 Version: 1.32.0.1302
CodeBase: file:///C:/Program%20Files/nLite/MCDBNET2.DLL
Accessibility
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Here is the configuration script I'm using from LAST SESSION.INI:
[Tasks]
Remove Components
Patches
Tweaks
Options
[Components]
;# Applications #
Accessibility Options
Briefcase
Charmap
ClipBook Viewer
Defragmenter
Games
Internet Games
NT Backup
Pinball
Screensavers
;# Drivers #
Asynchronous Transfer Mode (ATM)
Cameras and Camcorders
Display Adapters
IBM Thinkpad
InfraRed
ISDN
Logitech WingMan
MultiFunctional
Portable Audio
Printers
Scanners
SCSI/RAID
Sony Jog Dial
Tape drives
Toshiba DVD decoder card
;# Hardware Support #
ATM Support
Brother Devices
Gravis Digital GamePort
Logical Disk Manager
Multi-port serial adapters
Secure Digital host controller
Smart Cards
Sony Memory Stick
Teletext codec
Video Capture
Windows CE USB Host
Windows Image Acquisition (WIA)
;# Multimedia #
AOL ART Image Format Support
DirectX diagnostic tool
Images and Backgrounds
Intel Indeo codecs
Luna Theme
Media Center
MIDI audio support
Mouse Cursors
Movie Maker
Music Samples
Old CDPlayer and Sound Recorder
Speech Support
Tablet PC
Windows Media Player
Windows Media Player 6.4
Windows Sounds
;# Network #
Client for Netware Networks
FrontPage Extensions
IP Conferencing
MAC Bridge
Map Network Drives/Network Places Wizard
MSMail and MAPI
MSN Explorer
Netmeeting
NetShell Cmd-Tool
Network Monitor Driver and Tools
Network Setup Wizard
NWLink IPX/SPX/NetBIOS Protocol
Peer-to-Peer
Synchronization Manager
Windows Messenger
;# Operating System Options #
.NET Framework
16-bit support
Administrative Templates
Administrator VB scripts
Color Schemes
Command-Line tools
Desktop Cleanup Wizard
Disk and Profile Quota
Disk Cleanup
Document Templates
DR Watson
File and Settings Wizard
File System Filter Manager
Help
Input Method Editor
Logon Notifications
Manual Install and Upgrade
MS Agent
Private Character Editor
Remote Installation Services (RIS)
Save Dump Utility
Search Assistant
Security Center
Service Pack Messages
Shell Media Handler
Task Scheduler
Tour
Web View
;# Services #
Alerter
Application Layer Gateway
Autoupdate
Background Intelligent Transfer (BITS)
Beep Driver
COM+
Distributed Link Tracking Client
Distributed Transaction Coordinator (DTC)
DNS Client
Error Reporting
Event Log
Fax Services
Imapi
Indexing Service
IPSEC Policy Agent
Management Instrumentation (WMI)
Message Queuing (MSMQ)
Messenger
Network DDE
Network Location Awareness (NLA)
Performance Logs and Alerts
QoS RSVP
Quality of Service (QoS)
Remote Registry
Removable Storage
Secondary Logon
Service Advertising Protocol
Shell Services
SNMP
System Event Notification (SENS)
System Monitor
System Restore
TCP/IP NetBIOS Helper
Telnet Server
Terminal Services
Text Services Framework
Volume Shadow Copy
WebClient
Windows Firewall/Internet Connection Sharing (ICS)
;# Directories #
DOCS
SUPPORT
VALUEADD
;# Compatibility #
[KeepFiles]
msconfig.exe
[RemoveFiles]
clock.avi
[Options]
CABRecompress
ClassicSetup
BlackSetupBack
GuestName = ""
AdminName = ""
ProfilesDir = "%SystemDrive%\Documents and Settings"
TargetPath = "WINDOWS"
temp_dir = %USERPROFILE%\Local Settings\Temp
isovol = WinLite
isoatt = -allow-multidot -no-iso-translate -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
[Patches]
TcpIp = 16777215
UsbPoll = 125
DoUxTheme
DoSFC
[Services]
StiSvc,3
AppMgmt,3
AudioSrv,2
CryptSvc,2
HidServ,4
HTTP,3
HTTPFilter,3
IpNat,3
NDProxy,3
Netman,3
PlugPlay,2
ProtectedStorage,2
SamSs,2
SCardSvr,3
TapiSrv,3
UPS,3
xmlprov,3
LanmanWorkstation,2
RasAuto,3
RasMan,3
RemoteAccess,4
IpFilterDriver,3
IpInIp,3
DHCP,2
Browser,2
NetLogon,3
RpcLocator,3
NtLmSsp,3
LanmanServer,2
