Results 1 to 5 of 5
Thread: What service edit would cause this?
    _
    Mar 2004
    Little Elm, Texas
    When trying to run a downloaded .exe:
    Code:
    Error reading setup initialization file
    A Google search just tells me that it was a bad download. I've tried downloading it again only to the same result.
    I've been messing with some services tweaks so I'm pretty sure it was one of these. I plan on going back through each one of them, but figured this might yield a quicker result.
    Anyone care to help?
    Jan Bennett
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    Is it every executable you download or just one? Everywhere i've seen just says its the result of a bad download. If its only one file, someone may have uploaded a bad file to begin with. If you give me the link i'll try it out
    REBUILDING!!
    _
    Mar 2004
    Little Elm, Texas
    I think I might have figured it out, but my husband wanted ice cream, so I had to leave the car in the garage for a bit. When I get back I'm going to see if it has to do with the setup.ini file being in a different location from a possible previous download.
    Jan Bennett
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    This happens when you click on run instead of file save as.. and then run... it misplaces some of the installation files...
    its a fairly common problem with both IE and firefox if you have it set to clean your history often
    _
    Mar 2004
    Little Elm, Texas
    I don't remember what I figured out the problem was at the time, but it's fixed now...lol
    Jan Bennett
  1. Questions!
    By Yellow-Snow in forum Mobile Impact
    Last Post: 06-10-2006, 05:18 PM
  2. Pre-Release Thread: Frodo XM Service
    By frodobaggins in forum Software & Software Development
    Last Post: 08-04-2005, 04:10 PM
  3. What is the fastest wireless data service?
    By DrBuzzo in forum Wireless Communications
    Last Post: 04-22-2005, 03:57 AM
  4. No Serial Interface Service on NEW LG325
    By camsgs3 in forum PhoneControl
    Last Post: 12-19-2004, 08:20 PM
  5. Hauphauge customer service experience.
    By mhorton in forum General Hardware Discussion
    Last Post: 10-14-2004, 02:25 PM
