Results 1 to 8 of 8
Thread: BIG problem with Winlogon.exe
    Dec 2004
    Sweden
    I tried to use minlogon but had some problems with shutdown so I changed back to Winlogon.exe again. Rebooted and came to the old style login prompt. Tried to log in and it seemed to work but then windows logs me out and I get back to the login prompt. I can't get anywhere at all! Tried safe mode and last working config with no luck. Please help!
    Aug 2006
    Try pressing Ctrl+Alt+DEL. It will bring you to the classic login page. Login from there. Most probably it's your 'personal settings' got resetted.
    I encounter that problem from time to time as well. Above should fix it, well at least for me!
    Raw Wave
    Jun 2004
    On the beach
    Will probably due to your registry changes, I've had this happen before and in the past have had to rebuild from scratch. Sorry.
    Dec 2004
    Sweden
    It must have something to do with the reg changes. When I change back to minlogon everything worked. Someone said those reg values was ignored by winlogon if you change back but I guess not
    FLAC SFiorito's Avatar
    May 2004
    there's only one reg value added which is need for minlogon. winlogon is not affected by that reg value. did you by any chance delete your user profile directories after switching to winlogon?
    Dec 2004
    Sweden
    Ok I looked at the reg file I ran and it was NOT a single entry Look at the file submitted by SWC, second post in this thread Using minLogon to speed up booting and decrease footprint
    Thought it just contained the DWORD 0000017 thing but I was wrong. Can anyone please look at the file and tell me what to change back.
    Edit: Here is it http://www.mp3car.com/vbulletin/arch...p/t-47869.html
    May 2004
    you're supposed to use only one reg entry. the other one is the first reg file I posted, but then after more testing and research I found that it only needed one value.
    Dec 2004
    Sweden
    Thanks but too late for that now....how much damage do you think the first reg file did?
  1. Audio muted problem
    By Tsleon in forum RR Bug Tracker
    Last Post: 10-20-2006, 06:09 PM
  2. just installed my carpc, need help with big problem
    By Stillalive2029 in forum General Hardware Discussion
    Last Post: 07-26-2006, 10:25 PM
  3. Replies: 7
    Last Post: 08-19-2005, 12:11 PM
  4. Computer Building Problem
    By 0l33l in forum General Hardware Discussion
    Last Post: 05-09-2005, 02:52 AM
  5. BU-303 problem (software related)
    By blazinlow in forum GPS
    Last Post: 02-14-2005, 08:59 AM
