Results 1 to 6 of 6
Thread: minlogon - Problems installing files
    Oct 2005
    Hey guys. Just installed minlogon and it works great for speed...but the problem.
    I tried installing a couple programs and it says "unable to create a temporary folder to extract to" - possible cause you don't have proper permissions.
    So I try to go into my documents, and set the security permissions. But ...no security tab anymore. Anyone know a way around this?
    If not, anyone know the regedit required to go back to winlogon?
    Oct 2005
    So looking further ... the computer is logged in under minlogon as
    "computername\username"
    So by default I assume new user are not give administrative priveledges. The problem is I can't add a new user with a "\" in the name.
    Any suggestions?
    Ah ....could just be I had "simple file sharing" on...hang on.
    Aug 2006
    I have the same problems too under Minlogon. Sometimes it installs right, sometimes it doesn't.
    You don't need registry to get back to Winlogon. If you have a copy of Winlogon, replace it with the existing minlogon just like the way you replace Winlogon with Minlogon will do.
    Oct 2005
    Yea, was able to work around by switching back to winlogon. But would still like to retain admin priveledges through minlogon - or at least find a way to map the drive priveledges.
    Thanks for your input though.
    Aug 2006
    NP, Cheers!
    I do notice even when I did what I mentioned, I got the software to install, but I can't use it (e.g:Bootskin).
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by SentraVIP View Post
    NP, Cheers!
    I am using bootskin with minlogon and ewf also
  1. Replies: 12
    Last Post: 03-16-2009, 08:00 PM
  2. XP System Builder
    By SFiorito in forum WinNT Based
    Last Post: 03-19-2007, 06:13 AM
  3. Complete set of PSD's Files
    By MickW in forum RR Skins
    Last Post: 01-06-2006, 03:13 AM
  4. MINLOGON without ewf, easy install with files
    By syfenx in forum WinNT Based
    Last Post: 06-07-2005, 11:48 AM
  5. Touchscreen problems with nlite and minlogon
    By Ascension in forum WinNT Based
    Last Post: 06-01-2005, 06:18 AM
