Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Roadrunner runs like poop!!
    Dec 2006
    I am in somewhat of a dilema.. I am running a M10000 with 512 of ram with Windows Xp PRO Retestrak. I have done all of the Tweakhound tweeks and I tried the Minlogon tweek but I was unable to find the NTLDR at c:\.. I even got so desperate that I used the ultra ghetto windows search tool. My problem is that Roadrunner is killing the computer. The system seems to be running really fast but when I launch RR it dies to a slow crawl. I even pulled 1gb of OCZ plat ram out of my desktop and put it in there and it still put the memory usage up to 80-90% Does anyone know of any other good tweaks? Optimizations? or have I screwed up somewhere?
    Thanks,
    FLAC sama's Avatar
    Feb 2006
    London, UK
    NTLDR is on the root of your system drive. You need to show all files to see it in folder options
    Dec 2006
    I have it set to "Show hidden Files and folders" but still nothing 8(
    FLAC sama's Avatar
    Feb 2006
    London, UK
    what about show system files? (uncheck "hide protected system files...")
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by mk4tdi View Post
    Thanks,
    Make sure you do not have a port set for XM (IN RR config) if you have no receiver installed.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    FLAC SFiorito's Avatar
    May 2004
    you don't need to do anything to NTLDR to run MinLogon, but it sounds like you've got other problems that MinLogon won't fix.
    Nov 2003
    Netherlands
    i have the same problem.
    At first RR runs good, but then it gets slower and slower. and than i can't do anything anymore because it takes about 5 min for eich button to load.
    i am waiting for a solution.
    i also got 512 mb and running the epia m10000
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    flash problem? does the logo spin very slowly? delete the logo.swf from the skin folder and see what it runs like then, aslo what is your CPU % at?
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Nov 2003
    Netherlands
    no, the logo does work properly. It does not stutter or something like that it goes smooth.
    only the buttons do respond 5 min later and loading next song takes an hour the jump to the next song. These kind of things.
    FLAC sama's Avatar
    Feb 2006
    London, UK
    press ctrl-shift-esc and see what process is hogging things up
  1. RoadRunner uses, futures and configuration
    By marsk8er in forum Road Runner
    Last Post: 08-14-2006, 03:46 AM
  2. How to poop at work...
    By BoyNextDoor in forum Off Topic
    Last Post: 05-02-2006, 12:11 AM
  3. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 07:28 PM
