List of flash media cards I have confirmed to boot XPe with:
note: I have not yet found a CF card that was not able to boot XPe.
Transcend Industrial CF with Fixed Disk UDMA4 2GB (TS2GCF45I-D) - this one formatted NTFS using an XP CD, definitely one of the fastest FBA, boot, and operation in comparison to the other cards I have tested so far. I did the FBA through the Addonics IDE to CF Adapter, but afterwards I ran the card using the Addonics SATA to CF Adapter without problems. I assumed prior to doing this that I would come across device driver related issues, but there was none. I was unable to notice any difference in terms of speed compared to my 2.5" IDE drive, though HD Tach benchmarks showed otherwise.
A-DATA CF Turbo 8GB 120x - this one was detected Removable, I just did fdisk -> format -> bootprep and copied contents over. This one was slow speed
SanDisk CF 512MB - removable, fdisk -> format -> bootprep, slowest speed
SanDisk CF 4GB - removable, fdisk -> format -> bootprep, slowest speed
Transcend 4GB 120x(TS4GCF120) - this one was Fixed Disk - able to be formatted as both NTFS and FAT32 through regular means.
SanDisk Ultra II 4GB - removable, fdisk -> format -> bootprep, slow speed
SanDisk 256MB SD Card - removable, fdisk -> format -> bootprep, I used the Addonics flash media to IDE adapter for this one(capable of dma!). FBA was slow, but bootup was very fast. The
Windows loading screen only loaded 3/4 of the bar before the Welcome Screen showed. I can't imagine the speed with a faster SD card.
Seagate 4GB 3600RPM MicroDrive - removable, fdisk -> format -> bootprep, high speed image transfer and Hd Tach benchmarks but slow FBA. A noticable lag time for applications.
