Results 1 to 2 of 2
Thread: Question about getting pc into suspend
    Aug 2006
    Hi folks,
    I'm trying to figure out the way the powersupply/shutdown controller knows to suspend, and not shutdown/hibernate. Is this a setting in windows (xp)?
    I honestly did search for this, but i couldn't quite find the answer here...
    Constant Bitrate ankur's Avatar
    Aug 2006
    New Delhi
    You also need tp go into the power options in control panel and look for the power button options, change that to suspend. In your bios you should also look for support for the S3 mode in the power settings. If you do both these things, then even if the PSU sends a switch off signal, your PC will suspend. HOWEVER, you must ensure that the PSU retains power even after that or else your PC will just lose power, not good.
  1. Replies: 4
    Last Post: 03-21-2006, 08:00 AM
  2. FS: CarPC 2.4 startup/shutdown controller
    By evilragu in forum Classified Archive
    Last Post: 03-05-2006, 05:28 PM
  3. powering pc fans question
    By ashram in forum Power Supplies
    Last Post: 07-16-2004, 10:41 PM
  4. car pc, speakers question
    By icet in forum General Hardware Discussion
    Last Post: 02-27-2004, 02:42 PM
  5. dumb question. how do you turn on the pc?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 04-03-2001, 01:49 AM
