Results 1 to 5 of 5
Thread: Windows Vista
    Newbie CeNter's Avatar
    Feb 2007
    Windows Vista
    Do you use windows vista? I like Windows Vista and use hi, but Some programs not work.
    Jun 2005
    Houston
    yea i have been testing vista since november and i find that XP runs smoother if your PC is primarily ran by a front end then it really shouldnt matter what OS you run as long as it is funtional and fast
    Mar 2006
    Colorado, but Canadian!
    I have had Vista since M$ sent me the Beta's build 3xxx and up. And i have to say it looks nice, and now that it is "released" it works a lot better than the beta's where drivers like nvidia (anything above 6800 wasn't supported) and where there were very few drivers available for printers.
    The main advantage I see of Vista with frontends is the way it handles sound output. Instead of your usually wave, line-out, line-in, mic, and everything, it shows the program names themselves. So it would make it very easy to mute Winamp when GPS speaks and adjust the GPS volume to X and music to Y, and radio to Z. Problem now is that RR doe not make use of these Vista features, because obviously Vista is new. I think in the next release or two, there might be an advantage to using Vista. But now, it doesn't matter if you are running 95.
    1.9in x 2.9in -- 47mm x 73mm
    FLAC SFiorito's Avatar
    May 2004
    i'm running it on 3 systems: laptop, desktop, and media center. besides some driver issues (not MSFT's fault) it works great. and developing for it is great too...
    Elsewhere
    How about the Wiki?
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Windows Vista Beta... sleep?
    By Gearhead61 in forum WinNT Based
    Last Post: 10-26-2006, 05:47 PM
  3. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
