hey guys, am I just stupid? I can't find the dll files, dat, or sys files when I search for them from the extracted XPeSP2FeaturePack2007.iso
Am I missing something?
I've installed the horm as above works fine, but if I restart my pc I get the error recovery screen quoting that hibernation data is corrupt.
Any ideas ?
Inside the ISO there is the XPEFP2007.exe "self extracting cabinet", open it with 7zip or winzip, you'll find inside other folders and files: in the "rep" folder there are all needed files for ewf, horm, etc...
Followed all of the steps (....I think). When I run ewfmgr, i get a returne "Unable to find an EWF volume". Any ideas or info for this problem?
thanks,
Craig
________________________________
Pentium III
601mhz, 288gb RAM
60gb hard drive @7800 RPM (upgraded from 5gb!)
nlited Windows XP pro
Gateway Solo 2150 laptop
power switch extended
8" Lilli molded in-dash
project 75% complete
I just followed these instructions to get HORM working and it works perfect excellent!
Followed the instructions above after I couldn't get the "old way" to work.
I never found "horm.dat" file in my XPe install software so i simply renamed a empty text file to "horm.dat" and everything seems to be working.
Seems to be working quite well, cheers.
Sorry to bring up a dead thread BUT I'd like to say THANKS these instructions worked perfectly. I'm using minlogon, ewf and horm (finally) on my 2X 2.5 drives raid 0 this works great.
Ohh the the link for the reg file on the first post no longer works here's the updated link to SFiorito info.
http://granturing.blogspot.com/
P.S the horm.dat is in the XPEFP2007\rep directory after you extract it.
