Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: What the best antenna to get RIGHT NOW?
    Mar 2007
    Barrie, ON
    For a CarPC I am building. What is the best at this present time?
    Elsewhere
    First of all, we need to know what you need the antenna for.
    Since you posted in the Wireless Communications forum, I'm going to assume (possibly incorrectly), that it would have to do with either 802.11b/g or cellphone, as opposed to radio, satellite radio, GPS or SatTV.
    Now that we've done some deduction, the BEST is subjective and would completely depend on your circumstances, really. More details, please.
    How about the Wiki?
    Mar 2007
    Barrie, ON
    Has to do with 802.11b/g.
    Btw, whats the difference between g and b anyways?
    [Edit:] Oh, I see. "G" has a higher data rate.
    802.11b
    Release Date Op. Frequency Data Rate (Typ) Data Rate (Max) Range (Indoor)
    October 1999 2.4 GHz 6.5 Mbit/s 11 Mbit/s ~30 meters (~98 ft)
    802.11g
    June 2003 2.4 GHz 24 Mbit/s 54 Mbit/s ~30 meters (~98 ft)
    Low Bitrate crez79's Avatar
    Dec 2005
    WA
    Google is your friend
    The best is this by far because it supports mp3car.com. But as said, it depends on your circumstances.
    Yeah google!
    Mar 2007
    Barrie, ON
    What is the gain on that one?
    The only reason I'm asking, and I've checked the FAQ section. In the FAQ section they have threads on "whats the best GPS software" or "Whats the GPS receiver", "whats the best ..." But not one on the subject of wireless.
    I searched tons of pages on this sub-forum trying to deduce what the general consensus for best antenna was. However, I was unable to draw a definitive answer. Many people here are using different types of antennas, so I assume that there's no REAL best?
    However, what are the differences between 5Db and 7Db or even 15Db going to be like? I read somewhere that 5Db is better than 7Db, is this true?
    Mar 2007
    Quote Originally Posted by BradJ81 View Post
    For this question i would look at wikipedia and find this:
    Decibel - Wikipedia, the free encyclopedia
    there under the chapter 'Typical abbreviations' you will find where you are looking for
    To help you a little bit this is the text you search for:
    0 dBm means no change from 1 mW, in other words 0 dBm is 1 mW.
    3 dBm means 3 dB greater than 1 mW. 3 dBm is 2 mW.
    −6 dBm means 6 dB less than 1 mW. -6 dBm is 250 μW (0.25 mW).
    The higher broadcast strength the longer the distance between the sender and receiver can be.
    But the problem is just like a chain, it is as strong as the weekest chain.
    Mar 2007
    Barrie, ON
    So you're saying I could have the best wireless antenna but that might not matter because of environmental factors? Also depending on the strength of the AP signal as well?.
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Correct. The "best" antenna is one that works.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by BarryWoods View Post
    Like this one -->
    And if your router is a little POS, then you could have some huge dB antenna and it would make little difference. Also obstacles still affect these signals. So if your plan is to get a huge antenna and use it around your neighbourhood or something, not going to work.
    A higher dB antenna might allow you to park a couple of spots farther back from the Starbucks and still get a signal, but if you have a house, and will use it for data transfer/backup only kind of thing, I don't think you will see very much improvement.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    Barrie, ON
    What router do you recommend? The Orinoco one?
  1. Accommodating my GPS and WiFi antenna
    By portabuddy in forum Fabrication
    Last Post: 10-29-2011, 01:44 PM
  2. Radioshark to Car Antenna
    By theminor in forum Car Audio
    Last Post: 11-16-2010, 04:49 PM
  3. Calling all XM experts... 2 antenna wires vs. 1
    By Nola111 in forum Car Audio
    Last Post: 03-10-2009, 08:13 AM
  4. How well the 3 in 1 Antenna sold by mp3Car work??
    By Autonator in forum Wireless Communications
    Last Post: 12-02-2006, 11:02 PM
  5. Replies: 9
    Last Post: 04-22-2006, 09:22 AM
