Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: PCMCIA WiFi vs. USB WiFi
  1. #11
    Apr 2007
    USB all the way... I mounted mine inside my homemade antenna. It's working very well so far.
  2. #12
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    I'd just like to chime in and say that I had really good luck with my old Buffalo PCMCIA wifi card and a $10 external antenna that i found on eBay. I really don't like USB wireless cards, as far as I'm concerned wireless throughput is bad enough without trying to use the USB bus for networking as well. Also, I'm not convinced that the range is good enough. Sure, some will say that you can hack your USB adapter to wire up a huge antenna, but why void your warranty when there are other combinations that are proven to work.
  3. #13
    Apr 2007
    It doesn't matter, it depends on the transmit power and receive sensitivity of the radio not the form factor... I think the Engenius USB adapter has the best balance of power and sensitivity.
    Whatever you choose if you want distance then an antenna port is a must.
  1. Usb WIFI speed and power?
    By djmickyg in forum Wireless Communications
    Last Post: 01-19-2006, 04:20 AM
  2. USB WiFi adapters
    By DarquePervert in forum Wireless Communications
    Last Post: 10-15-2005, 08:19 AM
  3. USB Wifi WEP Testing
    By Tred in forum Wireless Communications
    Last Post: 07-23-2005, 03:23 PM
  4. Anyone want to trade? I have Wifi PCMCIA card, need USB!
    By Urinemachine in forum Classified Archive
    Last Post: 04-03-2005, 03:03 AM
  5. usb wifi with detachable ant?
    By meyer64 in forum General Hardware Discussion
    Last Post: 03-30-2005, 01:46 AM
