Results 1 to 10 of 13
Thread: PCMCIA WiFi vs. USB WiFi
    Mar 2007
    Is it pretty safe to say if using PCMCIA WiFi is most likely to connect to an access point than say an USB WiFi mounted at the rear window?
    At the moment, I have a TabletPC mounted under the center console (Nissan Altima 2005) under the AC dials. Using a Cisco Aironet 350 B wireless, and it picks up a few open access points no problem. I was just curious to know what if I had an external USB unit like this - Linksys WUSB54GP:
    http://www.linksys.com/servlet/Satel...=2762239789B47
    Currently I have an USB hub mounted under the trunk, I have hooked up the Microsoft GPS, wireless keyboard receiver and maybe this USB WiFi device if it's better.
    Or any other suggestions would be much appreciated.
    Elsewhere
    Quote Originally Posted by htsource View Post
    No. There are too many factors to even attempt a blanket statement like that.
    Perhaps a high-power WiFi device is the ticket? Search for SENAO on these forums. Several of us use this adapter and are very happy with it. It's far more powerful than a crappy USB wifi dongle and most PCMCIA wifi cards.
    How about the Wiki?
    Jul 2006
    I think you may want to search for Senao or Engenius. Here is something to get you started.
    Elsewhere
    Quote Originally Posted by LYHTSPD View Post
    D'oh!
    Pardon my typo (now corrected).
    How about the Wiki?
    Mar 2007
    Thank you guys for the link, I'm going to see if I can get one from Canada, but the price is pretty good. Do you think it will work with USB 1.1, or I need USB 2.0 to work? I don't mind the "B" performance but trying to avoid adding an USB 2 PCMCIA card to the Tablet if possible.
    Thanks again.
    Elsewhere
    I wouldn't use any USB wifi adapter on USB1.1.
    How about the Wiki?
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by DarquePervert View Post
    why not? If you are using b, and also transfering files through the internet, and not just an intranet, you will never realize the full speed of 2.0 anyways...
    Under ideal situations, you could, but realistically, I dont think it will happen
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    Okay, any suggestions as far as which PCMCIA USB 2 card to get, and a 4-port USB 2 hub as well?
    So far I have tried Adaptec USB 2 PCMCIA card, along with 2 USB 2 hubs, anything that I plugged into the hub didn't get recognized. If I used an USB 1.1 hub, everything worked okay.
    I may try another USB 2.0 PCMCIA card but so far the USB 2 experience hasn't been so good.
    Just to add, I only have 2 USB devices - MS GPS and Gyration wireless keyboard.
    Mar 2007
    Alright, one more question! So far I've planned to get the following to work:
    a) Gyration wireless keyboard
    b) MS GPS
    c) Bluetooth
    d) Wireless b/g adapter
    Tablet comes with one USB 1.1 port, a PCMCIA slot for a potential USB 2 card. If I use the PCMCIA card, I will still need a hub as most USB 2 cards have only 2 ports. Ultimately I want to plug everything to the hub and the hub will be hiding in the trunk. Would I be able to plug everyting into a hub and just one cable to the PCMCIA 2 card.
    I guess in this case, the hub should be powered?
    Thanks again for your help.
    Elsewhere
    Quote Originally Posted by 2k1Toaster View Post
    You're correct. I look at USB1.1 as a potential bottleneck. Whether it will be in real-world situations or not, I want to prevent that bottleneck.
    I've had broadband for too long. I guess I'm spoiled.
    b) MS GPS
    c) Bluetooth
    Yeah. A powered hub.
    The GPS can go into USB1.1. The data flow is far slower than even USB1.1 (4800bps).
    How about the Wiki?
  1. Usb WIFI speed and power?
    By djmickyg in forum Wireless Communications
    Last Post: 01-19-2006, 04:20 AM
  2. USB WiFi adapters
    By DarquePervert in forum Wireless Communications
    Last Post: 10-15-2005, 08:19 AM
  3. USB Wifi WEP Testing
    By Tred in forum Wireless Communications
    Last Post: 07-23-2005, 03:23 PM
  4. Anyone want to trade? I have Wifi PCMCIA card, need USB!
    By Urinemachine in forum Classified Archive
    Last Post: 04-03-2005, 03:03 AM
  5. usb wifi with detachable ant?
    By meyer64 in forum General Hardware Discussion
    Last Post: 03-30-2005, 01:46 AM
