Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: homemade wifi antenna
    Apr 2007
    I figure people would like to see why the heck I have a pvc pipe mounted as an antenna on by Ramcharger. Check out the pictures. It is a homemade omnidirectional wireless networking antenna with a built in USB dongle. I mounted it last night and drove around town with netstumbler and found access points EVERYWHERE. Although its kinda illegal to use someone's access point without permission, its ment to be used at truck stops and the sort. Many business have free WiFi internet now, even McDonald's. I specifically made this one for my business plan for Entrepreneurship class in college.
    The USB dongle is located in the steel pipe at the base. I used two small steel pipes for a cheep mount with two u bolts. I cut a slot at the top side of the steel pipe for the cable and sealed it with silicon. I'm contemplating painting it black and thus rip the silicon off for something paintable.
    Here is a link for antenna directions...
    http://www.nodomainname.co.uk/Omnico...4collinear.htm
    The antenna is considered a vertical collinear antenna... Let me know what you guys think.
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Nice, I've got a smaller one with a N female connection for my wifi card. The one I have is only about a foot long though. You should try one of the linux live cds and run kismet to really see what's out there. Netstumbler will only show you wireless access points that have the ssid broadcast turned on.
    Failure is not an option....
    It's installed by default on every version of Windows.
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I thought about mounting a 6 foot pvc pipe on my jag for an antenna. I would just mount it to the bumper. What are you using as the actual antenna?
    New Age Garmin - Skin for RR
    Constant Bitrate avengerki's Avatar
    Mar 2006
    Oregon
    So have you thought about selling this pipe dream?
    Avengerki
    PC Install: 85%
    Car PC: Revo-Sys X300 Double Din: 1.3GHz Pentium
    Software install and setup: 35%
    Entertainment Package: 85%
    Apr 2007
    I'm using a vertical collinear antenna with a USB dongle built into it at the base. See the link I posted...
    I have the adapter attached with a thin piece of coax now, but this is what it sorta looks like...
    I'm using the ZdYAS 1211 chipset now, and from what I read it's widely used with Linux. I'll give the liveCD a try before I go through the process of loading my spare computer with Gentoo or something. I think I'll try something easier than Gentoo this time though. Last time I tied I had trouble getting old RaLink drivers to work for a PCI card.
    I think the think I'm going to worry about the most right now is getting the antenna on a spring mount. I'm worried about hitting a tree or something. I am considering producing them. They would probably be sold for about $100 each, and the only competitor on USB powered antennas markets theirs for marina/boat use.
    May 2006
    Ohio
    Quote Originally Posted by ThunderStick View Post
    He posted the link for the antenna. The PVC is just the radome.
    Mar 2006
    Oregon
    I know that but he stated that he did it as part of his business plan for his entrepreneurship class.
    Avengerki
    PC Install: 85%
    Apr 2007
    I've considered producing them, but the idea is just for my project now. They are pretty hard to make and I don't see if being worthwhile unless I can figure out how to make one in an hour's time. I figure with a lot of small machine shop tools I can quicken the process dramatically, but I don't know to what extent in a 3 person startup shop. In my business plan I'm considering marketing it towards truck drivers and trucking companies possibly who want wireless. One person told me he wanted his drivers on wireless networking while idle in a parking garage.
    By the way, I haven't posted on this board in ages, can't find my old login and have no traces in my old email accounts at least on this computer. If anyone has been around here for like 6 years my name is Nick and I'm from Parma Ohio.
    May 2006
    Ottawa, ON
    Just a Gentoo update, they now support the Ralink drivers natively. all you have to do is
    Code:
    emerge rt2500
    . I currently use an old linksys with an rt2500 in it on my gentoo box and it works great!
    cheers,
    - Tam -
    May 2006
    Ohio
    Quote Originally Posted by nicksmurf111 View Post
    I'm pretty sure there's already a commercial usb antenna/wifi adapter unit that looks really close to this. Besides, you'd have to get fcc approval to sell one of these things, plus approval of the manufacturer of the wifi stick.
  1. Accommodating my GPS and WiFi antenna
    By portabuddy in forum Fabrication
    Last Post: 10-29-2011, 01:44 PM
  2. USB Adapter + External Antenna = $70 bucks worth of Wifi Improvement??
    By pjloppez in forum Wireless Communications
    Last Post: 03-27-2007, 06:56 AM
  3. Cellular WIFI Antenna?
    By scott011422 in forum General Hardware Discussion
    Last Post: 11-08-2006, 04:55 PM
  4. Recommend WiFi card and Antenna?
    By DaveB in forum Wireless Communications
    Last Post: 01-25-2006, 12:04 AM
  5. Tall Wifi Antenna
    By EBFoxbat in forum Wireless Communications
    Last Post: 11-22-2005, 07:43 PM
