This is a WAG, but it's not your user Library. It's the /Library/Modem Scripts/ folder.
OK I searched and came up with nothing for a 3G razr conecting to a mac. I did a search on google for this and found some different sites and the say I need to download a 3G modem script so I did then it says I need to drop the scripts into Library:Modem Scripts. I look in my library and ther is no modem scripts file. So how can I hook my Razr up to use the 3G network?![]()
As you sow, so shall you reep
My Install- http://www.mp3car.com/vbulletin/show...-10-4-lcd.html
Failure is not an option....
It's installed by default on every version of Windows.
Thanks I found it now lets see if I can get it to work
Works finally thanks Barrywoods
Yeah it stopped working already. I used it yesterday twice then third time It wouldn't connect said there was a modem error. Then today I got on once and it worked fine then it wouldn't let me get on again I had 4 or 5 bars so It wasn't my signal and the 3G icon was on in the menu of the razr. Anyone hooked up a razr and not had any problems?s
So I figured I have to manually turn off bluetooth then I have to make my phone discoverable. The automatic settings won't work.
