Results 1 to 10 of 14
Thread: Radar Jammer, Interesting Project!!!!!
    Variable Bitrate debugger's Avatar
    Mar 2006
    CA
    In theory it is possible to write software that will do the following:
    1. It will know the speed limit for particular location and your current speed through the GPS on your car PC.
    2. It will scramble or diffuse the signal if you going over the speed limit and reflect back the appropriate speed.
    3. It will work on all frequencies and Laser equipment.
    I wanna hear your thoughts on this....
    Aug 2007
    New Orleans, LA
    I'd say that this is next to impossible, if not impossible. Despite the fact that there are 3 bands of radar, and one of Lidar, to jam radar takes a LOT. Let's take the Ka band for example. Ka covers a range of mhz that it can transmit on. So, no two radar guns will shoot out the same radar frequency. This means that you have to figure out which frequency is being used, generate the correct reply reflection, and transmit it back on the right frequency. To make things worse, you have to do this in nanoseconds or less. You have to remember that radar and lidar guns work off of time differential and distortion to determine speed. IMHO, it's not worth the time to even investigate.
    Crawdaddy
    1991 Chevy Suburban 1500 w/SBC 350
    2005 Saturn ION 2 sedan
    Suburban Worklog
    "A local New Orleans man says his socks are finally dry..." -Tom Tucker, Family Guy
    Jun 2005
    radar jamming (strawberry)
    I have worked with military equipment that does this. It is ungodly expensive and sophisticated. There may be some cheap simple way to do this, but it is not immediately apparent.
    Jun 2007
    St. Louis
    I heard or read somewhere that the new F-22 raptor has jamming capabilities to augment it's existing stealth design. guess you could drive around with the nose cone from an F-22 strapped to your car...
    ...would go great with the park-bench spoiler screwed to the trunk lid
    Sep 2006
    SK
    Jamming, sure. They'll either get wacked out readings or more likely no reading at all. But trying to send back a modified signal to make it look like you're going a specific speed, that's probably not going to happen even if it is possible.
    On a somewhat related note, this article is interesting. http://www.wired.com/cars/coolwheels..._cannonballrun
    These guys drove from Manhattan to Santa Monica in 32 hours and 7 minutes with an average speed of 90 mph. They made good use of radar/laser detectors and jammers.
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Quote Originally Posted by DroStar View Post
    Don't forget the spotting plane.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Constant Bitrate Morpheus2010's Avatar
    Jul 2007
    orlando
    I am very interested in something like this
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by BarryWoods View Post
    Hey, you have a plan there.
    What you need is a remote control plane controlled by the PC, which stays a constant distance in front and relays pictures from it's nose cam so you can monitor for smokeys
    May 2006
    Ohio
    Quote Originally Posted by Enforcer View Post
    Till it plows into a highway sign. They'd probably charge you to fix it.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    How f3cking high do they have highway signs 124 miles south of the artic circle?
    Ans I wish they would stop adding f3cking words to their swear filter. f3cking cnuts
  1. Intro to building DigitalMods
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 09-24-2007, 02:11 PM
  2. Replies: 18
    Last Post: 07-26-2006, 10:50 AM
  3. DIN compatable PC project
    By don-m in forum Worklogs
    Last Post: 10-23-2005, 11:11 AM
  4. FS: Lilliput 8" LCD w/ 2 Project Housings
    By migel628 in forum Classified Archive
    Last Post: 09-14-2005, 07:40 PM
  5. Subaru WRX UK -- Full project
    By Muddy in forum Show off your project
    Last Post: 08-05-2005, 02:36 PM
