If your router is located such that its right above your car, you may get bad reception if both antennas (router and carpc) are both vertically polarized (vertical antenna). Most router antennas radiate strongly perpendicular to the antenna length and most weakly in the direction parallel to the antenna length. My coffee table in the living room is right below my wireless router and depending on where I put my laptop on the table, sometimes speeds can drop down to 1Mbps! So if you do infact get bad reception, you can try relocating the router, or angle the antenna of the router slightly /. For best overall reception in the car (eg. to pick up starbucks wifi), then the antenna on your carpc should be vertical, and not angled.
LinkBack URL
About LinkBacks
