Results 1 to 10 of 11
Thread: Wireless Only ever connects at 11mbps
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have an Alfa500mW. It's a USB 2.0 Network Controller. Broken down it's a realtek chipset. I have the updated drivers etc. My problemis that it only ever connects at 11.0 Never 24, 36, 54 etc... It is Wirelss G/B and my wirelss router at home is G/B. Even when within 2 feet of it only still only 11. I have tried many other connections as well and no luck. The card and router are setup for G...I have tried everything.. Any ideas?
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Quote Originally Posted by Dougw133 View Post
    Have you tried connecting a different adapter and that adapter with a different router? One or the other could be bad, damaged antenna or something internal. The first step is to see which device is the culprit. There is also the possibility of interference. Try moving both to a different location in the house.
    ~Jimmy
    Nov 2007
    PA
    I have tried with different routers so it is not them...I have tried both the utility provided as well as windows zero configuration.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Some routers allow "G" only operation. See if your router supports, and throw it into "G" only. Sounds like your adapter isn't doing "G" at all. You can check the device properties from the device manager and see if maybe it's set to "B" only. Sorry for such general instructions, I'm on my laptop, no windows here so I couldn't walk thru it to tell you what specifically to look for.
    Tidder
    Try RevFE
    Nov 2007
    PA
    Got ya...Thanks. I'll give it a try
    Nov 2007
    PA
    Alright well it connects fine at 54 when I set my router to "G" only. It seems it is prioritzing B before G. I don't see anywhere in the device settings to change this..
    Sep 2003
    New Mexico, USA
    Hmm... how strange man. Have you looked for new/older/different drivers for it? Maybe going back to an older driver, or using a driver for a different adapter that has the same chipset would knock this problem out.
    Tidder
    Try RevFE
    Nov 2007
    PA
    I have used two versions of the drivers as well as using the provided utitlity. Even with the CD that came with it this problem remains.. I have done a lot of seearching and it doesn't seem to be a common problem...Who knows...I am going to mess with it some more tomorrow. Thanks
    Newbie wolfebaine's Avatar
    Dec 2005
    Etters, PA
    you're plugging into a USB 1.1 port.
    02 Acura RSX
    Aspre Revo
    7" IMO USB Monitor
    XBMC
    Homemade control knob
    Mobile Internet via Blackberry
    Progress?
    <0%----------Infiinite>
    This project will never be complete
    Nov 2007
    PA
    I was just jumping on here to point out a possible USB problem...I have all USB 2.0 Capable ports on my Jetway C7 Motherboard, however XP won't recognize any of them as USB 2.0.. I have updated drivers etc...I am pullsing my hair out.
  1. FS: Linksys Wireless Items!!
    By adidas445 in forum Classified Archive
    Last Post: 04-27-2006, 05:12 PM
  2. Replies: 1
    Last Post: 03-12-2006, 06:46 PM
  3. FS:BB160 Wireless PC Card $5 each
    By kderedwolf in forum Classified Archive
    Last Post: 05-03-2005, 03:38 AM
  4. wireless card or wireless car and access point?
    By vanroth in forum Wireless Communications
    Last Post: 06-08-2004, 10:46 AM
  5. Compaq 11mbps wireless usb adapter
    By jol in forum General Hardware Discussion
    Last Post: 03-03-2003, 12:19 PM
