Connect my WIImote to pc - PROBLEM!
Hello, Last night I'v spend al the night on trying to connect my wiimote to the pc. I bought a normal bluetooth stick (12 euro's). I installed the drivers (widcom) and inserted the bluetooth stick. I'v read that you should skip pairing etc, so id did. After doing everyting by this tuturial : http://wiibrew.org/w/index.php?title=Wiimote_Tutorial
After that, the wiimote was flashing non stop. (So it should be connected, paired) Then i started GlovePIE, and ran the testwiimotescript, (wiimote still flashing) Tuturials say that the "debug" thing, should change in numbers as you wave your wiimote. Well, i can swing my wiimote as hard as i can, but the debug numbers don't change.
Also the mouse script doesnt work, only my cursor goes slowly to the corner of the screen.
I'v also tried Bluesoleil.. But it doesnt recocnise my bluetooth adapter, it just says: Place a bluetooth device.
I have no more ideas.. So if someone could help me???
Thank yOu!! :hippie:
