Results 1 to 5 of 5
Thread: Internal PCI-e wireless card, two leads?
    _
    Mar 2004
    Little Elm, Texas
    I'm trying to figure out what these two leads are for on this internal wifi card that I have.
    WLL4070-D50
    The chip is an Atheros AR5006X
    Anyone have any insight? One lead is black, the other gray. They both have very small circuit boards on the end of them. It's obvious that these are the antennas, but I'm wondering why there are 2?
    Any tips/tricks to boost the signal?
    Jan Bennett
    Constant Bitrate kibble's Avatar
    May 2008
    On notebooks/laptops there are usually two antennas mounted in separate places, I guess for overall best pickup/transmission of signals. The "circuit boards" at the ends are the actual antennas and have a particular foil pattern for the frequencies they're transmitting/receiving.
    I don't really know of any way to boost them, but then again I haven't really looked into it.
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    It's called antenna diversity. No way to really "boost" the antennas you have, but you can get a couple pigtails and mount bigger antennas. For diversity to work correctly, they should be about 5.5" to 5.75" apart. You can also just unplug the second antenna and just use the main with a bigger antenna.
    So what you hacking?
    Failure is not an option....
    It's installed by default on every version of Windows.
    _
    Mar 2004
    Little Elm, Texas
    Sweet! Thanks for that info. Makes perfect sense.
    It's just a laptop that I killed. It was old and I didn't use it much any more so I figured I would take it apart and see what I could use out of it. Basically, I was dumb and plugged a 12v power supply into an external CD-Rom that only needed 5v. It shorted out the board via the USB port and then the laptop wouldn't even turn on.
    Like a fingerprint reader....though, I'm afraid I don't know how to wire that thing up since it was a propritary cable for it.
    Regarding the distance between the two antennas, if they are further, will it matter? I'm going to try and figure out a way to mount them outside of the metal case, but then I'd worry about protecting them.
    Jan Bennett
    May 2006
    Ohio
    Quote Originally Posted by RedGTiVR6 View Post
    Yea, it will matter, it won't work as well. It's based on the wavelength of wifi radio frequency. For 802.11b+g it's between 4.75" and 4.89" from channel 14 to 1. Here in the US we can't use channels 12, 13, or 14. That chunk is given to medical equipment and stuff like that. I've used 4.75" center to center with no problems, from what I've been told, anything in that range should be good enough.
  1. H/W Review- PCI Vid Card 6200- umm $28
    By VehicrossPC in forum The Review Palace
    Last Post: 07-31-2006, 05:23 PM
  2. WTB/WTT: pci video card and pci wifi card
    By xdjxklusivex in forum Classified Archive
    Last Post: 07-31-2006, 06:12 AM
  3. The "Official" low profile card post
    By lakorai in forum General Hardware Discussion
    Last Post: 05-22-2005, 09:49 PM
  4. FS:BB160 Wireless PC Card $5 each
    By kderedwolf in forum Classified Archive
    Last Post: 05-03-2005, 04:38 AM
  5. PCI card riser card
    By allenruble in forum Classified Archive
    Last Post: 11-25-2001, 08:51 AM
