Results 1 to 10 of 14
Thread: An alternative solution to the echo problem in bluetooth phone...
    Feb 2008
    Well yesterday I brought back my car pc to home to make the bluetooth handsfree work. I searched for usb microphones; but I couldn't find one in stores. I didn't want to spend time waiting for a mic. so I didn't buy it from internet... Then I found Logitech Quickcam E2500 webcam! This webcam has an integrated microphone which also work through usb. Also the cam has a softwared echo cancellation system... I plugged the webcam, installed the software and just choose the webcam as microphone. Then entered the webcams program and checked the box "Echo cancellation...." The result is incredible! No echo at all and it is relatively cheap... But the program of the webcam should be running in order to use the echo canceling system...
    Sep 2008
    Nice, so you noticed almost 100% echo cancellation?
    Is there any way to separate the mic from the webcam?
    Oct 2006
    yeah the logitech orbit has a really nice echo cancelation feature, but its too big for me to put into the car, and plus i'm still dealing with centrafuse bluetooth delay.
    Sep 2008
    Yeah, Centrafuse really needs to step up and solve the delay and echo. Hardware based solutions would be best, but they keep digging at a software solution.
    Feb 2008
    I think it can be separated; but I didn't open the case of it and split it apart so I'm not sure. For now I have a place to put it; but in the near future if I buy my dream car (2002 9-3 aero convertable) I won't have the space so I'll be splitting it.
    And yes there is no audible echo.
    Feb 2008
    today I worked over it a little more and found out that this is not also a good solution at all!!
    By chance my audio setting, mic, wave and main levels were set up ideal for the mic of the webcam. Today I maximised the volume and wav etc, and listened music, then my phone rang, and opened the call, the person I'm talking said there was a big echo! I think it is because of the wave volume settings.
    So this cam is also is not an option I think. Excuse me; but at first I was so happy and I wanted to share; but now I'm frusturated!
    I think there is a very simple way to solve this problem... For example in dj softwares the program can control two different cards, so you can play two different music from two different cards and mix it with your hardwared mixer...
    Likewise if CF or RR used a phone program which we could assign another sound card, then all we have to do would be to buy a usb speakerphone (which actually they work like a soundcard). They are around 30-40 dollars, which is affordable I think. All of these speakerphones have echo cancellation which works very well...
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    well that is what this hobby is all about, trial and error, so dont be too frustrated. Im going to wait for IVT and Flux to fix the echo, after all IVT is the one that created the BT stack for CF, so I am sure they know what they are doing.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Oct 2006
    yeah i didn't even bother installing bt into my car for that very reason, its still very early stage. Its going to be a while, before its as good as everything else, Patience.
    Feb 2008
    I can say that this cam is far better than a analog mic and at least I can use the bluetooth stack now. But when somebody calls cf automatically minimizes the sound so that echo will be minimized. By that I solved my problem, but now its like somebody is whispering when I'm talking with phone!
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Just wondering if your solution helps at all with the delay problem? Ive manage to decrease my echo by lowering the mic and speaker volumes. But the delay is still very annoying...it's like trying to talk to someone internationally over a slow VOIP connection.
  1. Need help from Bluetooth phone integration gurus
    By Marassa in forum Software & Software Development
    Last Post: 06-08-2007, 01:34 AM
