Results 1 to 10 of 15
Thread: BT in centrafuse
    Nov 2008
    BT in centrafuse
    hi!
    please help on this matter because i'm going crazy!!
    it seems that I can't get the phone, CF navigation and igo8 to work at the same time...
    the phone is no problem, it always gets connected
    sometimes i get igo to connect to the bt gps, sometimes destinator, sometimes bluesoleil just crashes and "needs to be closed"
    any opinions on this? or even a simple solution that i'm overseeing?
    tnx
    edit: don't know it it matters but i'm using a wm6.1 phone
    Nov 2008
    anyone?
    laptop based e46 carpc
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by patrik999 View Post
    anyone?
    Have you tried posting over at the Centrafuse forums?
    Nov 2008
    ok, so I reinstalled everything and the same problem appears...
    the main issue is that the gps keeps getting disconnected in iGO8...every 15 sec or so...
    and if I turn off the phone in CF, it still gets disconnected...
    any ideas?
    Sep 2007
    I dunno what IGO is (GPS?), but it looks like you might need X-Port to dish out the GPS signal to your setup...
    Destinator needs it's own COM port, as does iGO (I assume)...
    Your phone, thru the BT, will also need a COM port (I think BS assignes two COM ports).
    Get X-Port, set it up to read the actual GPS data stream on the COM, then setup each GPS device with a COM port that you've configured in X-Port...see if that helps!
    Nov 2008
    tnx, I will test it
    Nov 2008
    that's it! it is all working now
    tnx a lot, wungun!!
    Sep 2007
    No prob Patrik...glad I could help!
    As soon as I saw 2 (or more?) GPS devices, I knew that wasn't gonna work on it's own!
    Nov 2008
    still I have problems...
    if my phone is disabled, the navigation won't connect to the bt gps module...
    it's like the phone is needed to start a connection between centrafuse and the module
    Sep 2007
    Hmmm...
    Your "BT GPS module", is that the iGo? I can recommend a USB GPS device instead, which would certainly eliminate BT issues with the phone...
  1. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 01:35 PM
  2. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  3. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
  4. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 03:59 PM
  5. Replies: 1
    Last Post: 08-08-2007, 11:41 AM
