blackberry AT commands described
I used hyper terminal to connect to my blackberry 8310 curve and get all the available commands, then i just used Google to look up each command, now i just need to know which commands i need to change in FreeFone to make it work, being inexpirienced with AT commands i don't know which FF needs to work.
ATA = Answer command
ATD = Dial command
ATDT = Dial command using tone
ATE = Command Echo
ATH = Hang up call
ATI =Identification
ATL =Monitor speaker loudness
ATM = Monitor speaker mode
ATO = Go on-line
ATQ = Result code suppression
ATS = Select an S-register
ATV = Define response format
ATX = Response range selection
ATZ = Recall stored profile
AT&C = Define DCD usage
AT&D = Define DTR usage
AT&F = Restore factory settings
AT+CBC = Battery charge
AT+CFUN= This command selects the level of functionality
AT+CGATT= return the modem command capabilities. This will list a few of the extended +G commands that the modem supports
AT+CGDCONT= used to select the Packet Data Protocols and Packet Domain.
AT+CGMI = Request manufacturer identification
AT+CGMM = Request model identification
AT+CGMR = Request revision identification
AT+CGREG =Network registration reporting
AT+CGSN = Request product serial number identification
AT+CGQMIN = QoS profile. See http://mybroadband.co.za/vb/archive/...p/t-18042.html
AT+CGQREQ= QoS profile. See http://mybroadband.co.za/vb/archive/...p/t-18042.html
AT+CGEQMIN= 3G quality of service profile (minimum acceptable)
AT+CGEQREQ= 3G quality of service profile (requested)
AT+CHUP = Hang up call
AT+CIMI = Request international mobile subscriber identity
AT+CLAC = List all available AT commands
AT+COPS = Operator selection
AT+CNUM = Subscriber number
AT+CPAS = Phone activity status
AT+CPIN = PIN control
AT+CSCS = Select TE character set
AT+CSQ = Signal quality
AT+CREG = Network registration
AT+GCAP = Request complete capabilities list
AT+GMI = Request manufacturer identification
AT+GMM = Request model identification
AT+GMR = Request revision identification
AT+GSN = Request product serial number identification (IMEI)
AT+RIMMOLR= ?
AT+RIMMTLN=?
AT+RIMRADIO=?
whoa, this is fantastic
i will be using this @ my job.
i provide blackberry support for the user's in my company.
i will have even more jargon @ my arsenal lol
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
