Results 1 to 5 of 5
Thread: Bluetooth to Bluetooth - is there such a device?
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Baltimore, Maryland, United States
    Blog Entries
    86
    Do you guys know if there is anything out there that is like a bluetooth transmitter and receiver kit? Basically it would allow any device that can output audio to transmit it over a2dp to any device that accepts input. For example I would plug sed device into my iPod and then the receiver into my speakers line input. It would basically be a wireless 3.5mm male to 3.5mm male cable in a sense.
    Any suggestions? Thanks.
    May 2009
    i did a quick Google search and came up with this.
    http://www.chaatakindia.com/ci_produ...streomm003.htm
    and this is my search
    bluetooth transceivers for music
    Antenna Engineer
    optikalefx's Avatar
    Apr 2009
    Blog Entries
    86
    Hmmm, I came across them before, they don't list the price, haven't responded to my email and don't ship to US. Ill keep searching.
    I think I found a solution. I found a BT receiver for 12 bucks and I already have a BT dongle so I'll see if that works.
    May 2008
    If you need to go from audio-out to audio-in you could get these.
    Dec 2008
    this is what i use. it is excellent in quality. you can detach the receiver from the speakers, and it is just a bluetooth receiver with 3.5mm output. the speakers also are high quality, sound excellent and run off 4xaaa's if you need it too (perfect camping solution)
  1. HQCT Module (new thread following HU RDS/RDBS)
    By racemier in forum Hardware Development
    Last Post: 12-15-2011, 03:14 PM
  2. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  3. XM Direct controlled from Windows Mobile Device via bluetooth
    By tampajohn in forum Hardware Development
    Last Post: 09-20-2007, 09:59 PM
  4. Please Help! Widcomm 4 Bluetooth problems...
    By shmartyn in forum Wireless Communications
    Last Post: 07-28-2007, 07:09 PM
