Results 1 to 10 of 14
Thread: Using CarPC, phone, and BT headset (is it possible?)
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    Hi, I'm trying to connect both my Headset and Phone to my CarPC via Bluetooth. The idea is that I'd talk on the phone using the headset (mic/speaker) and be able to dial using the CarPC, but I'm running into some problems.
    Hardware:
    Dongle: MSI Star Key v.2
    Headset: Motorola H12
    Phone: Motorola RAZR (I know, it's old and needs an upgrade)
    Software:
    BlueSoleil 6.4.289
    Each of the devices function perfectly when they are the only one connected to the computer. I can record and listen to music through the headset when it is the only thing connected to my carputer via Bluetooth. Similarly, I can make calls using my carputer when my phone is the only thing connected, but I can't seem to do both. I think the problem is that both devices are trying to connect using the Headset Profile. I assume 2 devices can't use the same profile at the same time?
    If that's the case, is the only way to use a phone on the CarPC to have a dedicated microphone in the car, and to listen to the call through the car speakers? Or is there another solution?
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Its entirely possible...one device is a headset source and the other is a headset sink.
    Jul 2008
    From my experience some phones have difficulty maintaining 2 separate bluetooth connections simultaneously. If you think about it from the phones side it needs to maintain a bluetooth connection with the headset and the car pc. About a year ago I tried the same thing but got the same results you are experiencing using 3 phones - 1 windows mobile htc touch, 1 sony w850, 1 motorola razr.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    ...which is why you have both the phone and the headset connected to the computer and let it route the audio
    Jul 2008
    Quote Originally Posted by justchat_1 View Post
    Since I know you're somewhat of a car pc guru I won't doubt you but I'm having difficulty understanding how this would be accomplished successfully in a car pc set up. I understand what you're suggesting but in the past I tried doing this also and was never successful getting the proper bt services to be friendly and just work reliably.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Well the main issues i've heard people have are routing the audio within windows. Its not too difficult with vista/7 but with xp it requires third party software. If the issue is truly on the bluetooth side make sure you pair each device with the pc separately, that you have two pairs of bluetooth audio devices in windows (should be automatic after pairing both) and then finally deal with routing the audio between.
    Bay Area, CA
    what specific hardware are you guys using to connect both a headset and phone to the carPC via Bluetooth? I can get each of them to work the way I want to separately, but when I try to use both at the same time, nothing works.
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    I don't think the RAZR can handle 2 BT connections. I have a 3G RAZR I used to use daily and it would not.
    The phone I now use, a Mot Q3h WinMo smartphone, *can* handle simultaneous BT connections. I use it with MyMobiler which is a WinMo remote control program but I do it over a USB cable because I've had difficulty getting that to work over BT. I can still use the BT headset if I want to, or use the speakerphone function.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Hardware based Handsfree protocol is almost always limited to a single SCO (Audio) channel in phones. Software based handsfree (smartphones and PC's) are only limited by bandwidth which usually allows about 3 SCO (Audio) channels (sometimes a lot more). Of course this may also be software limited but I know it can be done on widcomm based software (like the windows bluetooth stack in vista+).
    Bay Area, CA
    Yeah, the RAZR can only handle 1 connection at a time, but what about connecting both to the PC? My dongle only supports Headset Profile (HSP), and not (HFP). I assume that I can't have both my phone and headset using the HSP?
  1. An interesting solution to adding phone support to CarPC
    By AvWuff in forum Hardware Development
    Last Post: 02-08-2009, 12:35 AM
  2. Replies: 6
    Last Post: 10-12-2008, 03:26 PM
  3. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 08:31 PM
  4. Mot V551 BT - PhoCo and/or Headset
    By Zogg in forum PhoneControl
    Last Post: 09-29-2005, 11:49 AM
  5. BT connectivity to Carpc and Headset
    By wysocki in forum PhoneControl
    Last Post: 03-18-2005, 12:10 AM
