Results 1 to 10 of 11
Thread: Audio streaming over bluetooth
    Mar 2007
    South Australia
    Hi everyone, I am considering a major over haul of my current carputer system. I wont go into the finer details but I am looking for some feedback or experiences good or bad from anyone who has used a bluetooth device to stream audio. The type of product I am considering using can be found here http://store.apple.com/us/product/TY277LL/A
    In short i would connect this device directly to my amplifiers and my new carputer substitute AKA iPad would stream audio directly to this device over bluetooth. I am considering this option instead of using the iPad doc connector as its line out only and volume control can not be controled on the iPad itself and I don't like the aesthetics of connecting via 3.5 headphone jack.
    Has anyone used a similar device to stream music over bluetooth and what was the sound quality like? The audio system I currently run is high end equipment and I'm a little concerned about audio quality.
    Thank you in advance
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    As I said in the other thread:
    Quote Originally Posted by justchat_1 View Post
    Might want to have a listen to Bluetooth audio in a vehicle before you commit to it as your primary method....quality is pretty good but it cuts out a lot when theres other bluetooth devices near or if theres interference of any kind (which happens a lot more then it should).
    It's cool for connecting a phone to a headunit as a temporary measure but you will regret using it as the main audio connection. Also, functional range is only about 5'...past that bandwidth is too low to avoid stuttering.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The reviews say that it sounds very good. I use a super cheap A2DP for audio and it sounds pretty good to me but I'm also not very picky. Good enough is good enough.
    If you're overhauling your audio system, it may not be good enough for you.
    Also, one of the main complaints was that your iPod didn't automatically connect to it when you came into range. I've experienced that with my bluetooth device. I think there's an order to turning on the device before it will pair automatically -or it has to have been connected to that device when it went to sleep. Not sure which as I haven't seriously investigated it yet.
    Also, you may not like the aesthetics of the iPad jack connector, but you may end up trading battery life for it. I think you'll find that it may be better to build some kind of dock mechanism for the iPad and integrate the power into that or the iPad won't last that long on battery with everything running on it.
    Want to:
    Mar 2007
    South Australia
    Crap I just read in a review that volume control doesn't work on the iPhone.... Wonder if this will change in an update. Bugger back to the drawing board. I wonder if the other brands have the same issue?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    This one is the one I use and it controls volume but the fast forward doesn't advance the track.
    http://www.dealextreme.com/details.dx/sku.8422
    Want to:
    Mar 2007
    South Australia
    Quote Originally Posted by Bugbyte View Post
    I'm looking to be able to control the volume directly on the iPhone or ipad plus this device looks like it can't be in use and charging at the same time. Thanks anyway.
    Mar 2007
    South Australia
    Bugbyte can you confirm if your device can be charging and in use at the same time
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Not without modification. The charger plugs into the headphone jack, so you are either charging it or using it to listen to audio. Fixing that will require opening it up to see if it is even possible to change that.
    Want to:
    Mar 2007
    South Australia
    Doesn't sound promising, Don't suppose anyone knows of any other brand that can be volume controlled by the iPhone? There is a RIM blackberry one but can't seem to find out if the iPhone volume control works on it.....
    Jan 2009
    Naples, Floridaaaaaaa
    I have one of these hooked up to my truck stereo: http://www.cellularinnovations.com/product/12
    I have a w08 watch/phone that interacts with the device and picks up calls and can stream music from my W08. im happy with it.
    The low budget model ! 2005 F-150
    • -Custom fiberglass console, CB,Interfaced OBDII
    • -In-dash multimedia w/ bluetooth
    • -Piconet PAN & Wifi Edge internet
    • -Advantech relay board, Pololu microcontrollers w/servos
    • -Embedded Axim palmtop w/backup GPS
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 06:25 PM
  2. Bluetooth audio streaming
    By totallyclueless in forum Wireless Communications
    Last Post: 10-19-2009, 02:20 AM
  3. bluetooth handsfree with audio output
    By diiirk in forum General MP3Car Discussion
    Last Post: 08-30-2007, 12:59 PM
  4. Recording Streaming Audio
    By xanimal in forum Software & Software Development
    Last Post: 07-29-2005, 02:06 PM
